Apr 25th, 2024, 11:52am
Varactor CV curve (Read 6662 times)
pumba007
Varactor CV curve
Feb 24th, 2012, 8:12am
Hi All,
I need someone to comment on my testbench for simulating varactor CV curve in cadence spectre. Pls find the attached image.
I calculate the capacitance from calculator -imag(i/v)/(2*pi*f).
I run ac simulation and sweep the control voltage of the varactor. I am not sure if this setup is correct because when i plug in this value in LC oscillator, i do not get the expected oscillation frequency. The frequency deviation is too large. Am i missing something in the setup?
Is there other methods to obtain CV plots more efficiently?
Mani
rfidea
Europe
Re: Varactor CV curve
Reply #1 - Feb 24th, 2012, 8:24am
It looks like you are using a MOS varactor. Those varactors has a very sharp transistion from min cap to max cap over tuning voltage. Your oscillator has probably a larger voltage sving compared to the voltage transition region of the varactor. This means that your effective large signal capacitance will have another value compared to the small signal value.
