Apr 19th, 2024, 11:31am
pre driver design technique for CML Driver (Read 8587 times)
DP_Design
Seoul.Korea
Mar 28th, 2012, 7:39pm
I am designing PMOS CML Driver for 3.3Gbps and output swing is about 300mV with gnd-terminated 50ohm at TX and gnd-terminated 50ohm at RX.
The driver output swing can be small, but while designing pre-driver,
I found pre-driver output swing should be much higher than that of driver,
Of course, the Pre-driver is also PMOS CML buffer with gnd-terminated R.
And I found the output of pre-driver waveform had a lot of H/L skew because the fall-time is dependent on the R while rise-time is dependent on PMOS. But I can't decrease R because to get proper pre-driver swing decreasing R means pre-driver bias current should be increased.
So I am stuck at this problem.
Please let me know design technique of CML pre-driver if possible.
Thank U.
View Profile DP_Design   IP Logged
raja.cedt
Re: pre driver design technique for CML Driver
Reply #1 - Mar 29th, 2012, 2:33am
why don't you post schematic???
DP_Design
Seoul.Korea
Reply #2 - Mar 30th, 2012, 12:50am
I attach my driver.
To get proper predriver output swing from 0 to about 700mV at Vdd 1.2V,
I use R1~400ohm , and Pre-driver output P/N cross point is about 400mV.
I want to know how pre-driver output waveform is and what is alternatives of big R or more current to get proper pre-driver swing,
and what is the proper pre-driver swing for this design.
Thank you for your attention.
Reply #3 - Mar 30th, 2012, 2:52pm
Get rid of the resistor pull downs in the predriver and go to a nmos down and pmos up predrive system
You may need to investigate clock boosting techniques in the predriver to cleanly get the output device driven to triode.
DP_Design
Seoul.Korea
Reply #4 - Apr 1st, 2012, 7:13pm
Thanks loose-electron.
You suggested that the pre-driver should be CMOS inverter-type and it would be better to use clk boosting scheme. Am I right?
But, I heard "to make jitter and skew smaller, use identical buffer of even number" so, I made pre-driver CML.
Is it ok to use CMOS pre-driver of CML driver?
And if the output swing of Pre-driver is full swing,
then I think Data dependent jitter or H/L skew of Driver would be bigger.
Reply #5 - Apr 3rd, 2012, 9:47am
This is on the transmit side, consequently you are worried most about the driver characteristics and power efficiency. Using a class B driver makes more sense.
