Mar 28th, 2024, 10:06am
Understanding differnce bw Phase Slew Rate and Jitter Tolerance (Read 877 times)
Mayank
Jul 20th, 2012, 1:49am
I have a doubt regarding difference bw 2 different specification quoted in USB3.0, Phase Slew Rate and Jitter Tolerance.
It says that Digital Clock Recovery ckts have a certain phase slew rate limitation - given by Phase update rate * Step Size. --> Understandable.
Q1. Won't analog CDRs have a limited slew rate ?
Q2. If we are obeying a certain JTOL, does that mean I am obeying a Slew rate limit equal to a -20dB/dec slope line passing through the corner point of the JTOL curve. [corner point = where JTOL curve becomes flat]
Q3. If slew rate -20dB/dec line is above JTOL, does it mean I have to design a CDR with jitter tolerance equal to the limit from Slew rate spec ?
--Mayank.
BackerShu
Re: Understanding differnce bw Phase Slew Rate and Jitter Tolerance
Reply #1 - Jul 31st, 2012, 1:05am
Hi Mayank, very interesting question.
For digital implementation, as you said, it is understandable since the maximum phase update rate is somewhat a fixed value, which is depended on the proportional path gain. This paper has a pretty good explanation on it; just in case you haven't checked this paper yet.
[1] R. C. Walker, “Designing Bang-Bang PLLs for Clock and Data Recovery in Serial Data Transmission Systems,” pp. 1–12.
For the analog CDR, I am not exactly sure. Here are my understandings to your three questions:
Q1: Yes, I think so, and the Phase Slew Rate is decided by the maximum speed charge pump can charge the capacitor in loop filter. In other words, it should related to Icp/sC.
Q2: Again, theoretically I think so, but this would be the minimum requirement of Phase Slew Rate to certain meet JTOL requirement. Some margin is necessary.
Q3: I am not sure what do you mean here. If you are still think about meeting the JTOL requirement, reduce the Slew Rate would be better since it will save some power.
Correct me if I am not right.
depend135
Reply #2 - Oct 22nd, 2012, 8:29am
Hi, Backer,
I think for the first question, it depends on the type of the phase detector. For the analog CDR with a bang-bang PD, it also has a limited phase slew rate which is controlled by the propotional path and is not related to the loop filter capacitor.
For the CDR which uses a linear PD, its phase tracking speed is limited by the bandwidth instead of slew rate since its output phase is not slewing.
What is your thought?
Dep
BackerShu
Reply #3 - Nov 15th, 2012, 11:32am
depend135 wrote on Oct 22nd, 2012, 8:29am:
Dep
Agree with you!
As long as the phase error is within the range of liner PD, the update rate is governed by bandwidth.
Thanks for clarifying this point.
