Sep 26th, 2024, 10:13pm
low power opamp design problem (Read 869 times)
lhlbluesky_lhl
Sep 15th, 2012, 2:50am
now, i want to design a very low power opamp (miller two-stage or symmetric single stage), what is the minimum value of branch current that can be accepted in normal 0.35um process?
if the bias current is 100nA (or lower) for every branch, what problems can be generated? and what considerations should be take for the low power opamp design? if the bias current is very small (nA order), then, what is the influence on offset, leakage, mismatch, and so on? can subthreshold leakage happen? besides, how is leakage current generated? is it related to body effect or subthreshold operation?
thanks all.
lhlbluesky_lhl
Re: low power opamp design problem
Reply #1 - Sep 15th, 2012, 7:11pm
is there any suggestion?
Reply #2 - Sep 16th, 2012, 8:10pm
start with some basic research.
analog_wiz
Universe
Reply #3 - Nov 20th, 2012, 8:19pm
You will be able to design with 10nA first stage and 100nA second stage. The design will go through. Some issues you will will need to live with:
1. Very low bandwidth(Hence very long settling time in case of coupling on critical nodes)
2. Low currents are good for input transistors noise performance but not for load transistors which need better vdsat's for better noise performance. The need to analyze all these will again depend on the particular application you are designing for.
You can refer holberg which has a nA opamp design. You should be able to find some more considerations there.
