Sep 26th, 2024, 10:17pm
audio amplifier design (Read 3201 times)
aman gupta
India
Oct 14th, 2012, 7:17am
I am studying basics of analog circuit design from microelectronics circuit analysis by donald neamen
And in that i encountered a problem in design of audio amplifier.
The question and solution is given in the attachment.
And i want to know that in the output emitter follower why there are no biasing resistors apart from emitter resistor ?
Hope my question is clear and if not then please do tell me. I want to clarify this
Thank you
buddypoor
Bremen, Germany
Re: audio amplifier design
Reply #1 - Oct 14th, 2012, 8:06am
My interpretation of the diagram is as follows:
An input dc bias current is shown (Ib arrow) which means that, of course, a base-emitter dc voltage of approx. 0.6...0.7 volts is necessary.
However, a corresponding resistive divider is not shown - but this does not mean that it shouldn`t exist!
As another solution the corresponding bias is provided by the dc output voltage of the preceeding gain stage, which in this case must be dc coupled to the output stage.
Reply #2 - Oct 15th, 2012, 6:14am
Hi aman gupta,
Why does it need additional biasing resistor apart from the emitter resistor? The emitter resistor and the base voltage determines the bias current, IE.
BTW, please make your question more clear. I guess resistor RE1 Figure 6.77 is what you said emitter resistor. Am I correct?
Yawei
aman gupta
India
Reply #3 - Oct 15th, 2012, 7:48am
ywguo wrote on Oct 15th, 2012, 6:14am:
Hi aman gupta,
Yawei
I am refering to emitter resistor RE4
in fig 6.78........... I was asking why we can't use voltage divider biasing in emitter follower in fig 6.78
But i think what buddypoor said, makes sense.
So is the operating point of emitter follower in fig 6.78 is being set by gain stage ???
raja.cedt
Reply #4 - Oct 15th, 2012, 8:07am
hello,
please refer to a basic electronics book. or else watch vedio's from thsi website.
here is the explanation:  Yes you can use potential divider, but you have to AC couple the bias coming from the previous stage. But why you want a resistive divider when you are having bias from some where....
The idea of resistive divider is to get the rite voltage at the gate of the transistor, when you have higher than required you are well come to do all those things, but fortunate you have bias from previous stage...
raj.
aman gupta
India
Reply #5 - Oct 15th, 2012, 8:17am
i got it...
thanks everyone
this site is really helpful.........
