Sep 26th, 2024, 10:15pm
How to evaluate specification of SAR ADC for biomedical(ECG)? (Read 1715 times)
Penny3GS
Oct 17th, 2012, 1:36am
Hi gentlemen
I want to design a SAR ADC but i don't know how to evaluate specification of SAR ADC.
Maybe thesis or book or any other application note can help me
I am doing some research and i got some result
Resolution:10 bits
channel:1 ch
sample rate:1kHZ (not sure)
ADC structure:
1.Charge-Redistribution
2.Binary weight
3.bipolar ADC
4.single end
Final target i need to do ultra low power for this ADC
So how to evaluate specification and reasonable?
Attach file is ECG waveform
Thanks for gentlemen
« Last Edit: Oct 17th, 2012, 10:22pm by Penny3GS »
Re: How to evaluate specification of SAR ADC for biomedical(ECG)?
Reply #1 - Oct 23rd, 2012, 4:38pm
QRS complex waves eh?
Looks good, no atrial fibrillation, or tachycardia...
Is this something you are designing into an IC or purchasing a device for off the shelf design?
You also mentioned low power and bipolar design.
If you are designing an IC consider CMOS to keep the power low.
Penny3GS
Reply #2 - Oct 24th, 2012, 12:00am
To loose-electron
Yes,i use TSMC 0.18 to design it,but still not sure the spec Undecided
Lex
Eindhoven, Holland
Reply #3 - Oct 24th, 2012, 12:31am
Interesting subject. Sadly I don't know much about it, but I'd guess you first need a SNR, BW and Voltage range requirement.
As loose-electron pointed out, there are many kinds of heart rhythms possible. I can image that in case of a fast heart rate (160 bpm or more) you'd still want accurate images so that probably defines your BW requirement. Very weak heart functioning (given small amplitude) will probably define your SNR. And so on.
Why don't you talk to a specialist/cardiologist to discuss the types of 'input signals' and output requirements (i.e. what is important for the persons inspecting the ECG)?
boe
Reply #4 - Oct 24th, 2012, 10:46am
you should also consult the relevant standards.
- B O E
Penny3GS
Reply #5 - Oct 25th, 2012, 1:50am
« Last Edit: Oct 25th, 2012, 9:50am by Ken Kundert »
Penny3GS
Reply #6 - Oct 25th, 2012, 2:03am
To Lex and boe
I try to find standard for ECG application before,
unfortunately I can't find that (BTW  if someone know standard for ECG application,please give me hand,thanks)
So second plan is find ECG sensor and follow up this spec for this application!
The document i attach in the my post,
and do a spec list below maybe everybody clond give me some opinion,thanks
SNR:60 dB
Feq:0~150 HZ
Voltage range:-0.2 mV~0.8mV
Lex
Eindhoven, Holland
Reply #7 - Oct 26th, 2012, 5:19am
Needless to say maybe, but the 50/60 Hz is in your range. I don't know how large this interferer is at the point you measure, but I guess I'd like to prevent this signal clipping/distorting the readout circuit.
boe
Reply #8 - Oct 29th, 2012, 11:56am
Penny3GS,
Penny3GS wrote on Oct 25th, 2012, 2:03am:
I strongly recommend you make sure you know the relevant standards before trying to build such a system.
- B O E
