Sep 26th, 2024, 10:17pm
high Q bandpass filter design (Read 5785 times)
lhlbluesky_lhl
Oct 21st, 2012, 1:54am
i want to design a active bandpass filter, Q>10, center frequency f0=20KHz, stop band attenuation as large as possible, and use as small as possible external components, and only one off-chip component is allowed (a R or a C), the other components to be on-chip, what type of BPF can i use?
in my opinion, i want to design a two-order BPF, but as i know, f0 is usually decided by at least two R and two C, such as f0=1/(sqrt(C1*C2*R1*R2)*2*pi), so if i use only a R or a C to tune the f0, the linearity is not better.
besides, the opamp non-ideal characteristics can have much influence on the BPF performance. so, how to consider this or how to design the opamp parameters (such as DC gain, GBW, PM, etc).
thanks all.
Dan Clement
Salt Lake City, Utah, USA
Re: high Q bandpass filter design
Reply #1 - Oct 21st, 2012, 6:01am
Look into doing a GmC filter.
Reply #2 - Oct 21st, 2012, 3:58pm
Define your requirements better
"Out of band rejection as high as possible"
Needs to be quantized.
After that? Define you S-plane function as needed.
Also, consider an ADC and a FIR filter at that low a frequency.
gmC that low? Nowadays I don't do gmC till I get above 20MHz.
lhlbluesky_lhl
Reply #3 - Oct 22nd, 2012, 5:10am
hi,  loose-electron. why gmC cannot get that low frequency?
Dan Clement
Reply #4 - Oct 22nd, 2012, 5:37am
The power of GmC can be high for lower frequencies.
lhlbluesky_lhl
Reply #5 - Oct 22nd, 2012, 5:54am
why? for a given C, the lower f0, the lower gm, and the lower the power. right?
Dan Clement
Reply #6 - Oct 23rd, 2012, 4:56am
The minimum power is really set by the technology.  So below a min frequency the area and power is not used efficiently.
boe
Reply #7 - Oct 23rd, 2012, 7:02am
lhlbluesky_lhl wrote on Oct 22nd, 2012, 5:54am:
And the higher the noise and the larger the mismatch.
- B O E
Reply #8 - Oct 23rd, 2012, 4:33pm
lhlbluesky_lhl wrote on Oct 22nd, 2012, 5:10am:
You can do a gmC filter at any frequency but the transconductor
design often requires a lot of bias current to maintain linearity
Generally I will use a gmC filter for higher frequency applications
(20-500 MHz) and below that look into something based upon op-amps,
switched capacitor design or ADC and FIR filter.
If you are going to hit an ADC anyhow, I would use a minimal
filter for aliasing and then ADC and FIR filter.
