Sep 26th, 2024, 10:17pm
diode circuit (Read 2256 times)
aman gupta
India
diode circuit
Oct 28th, 2012, 5:47am
please tell the output voltage mathematically or graphically
raja.cedt
Re: diode circuit
Reply #1 - Oct 28th, 2012, 10:38am
hello,
please find the attached plot.
Raj.
aman gupta
India
Re: diode circuit
Reply #2 - Oct 28th, 2012, 12:06pm
@raja   what is the Vo at the point of change of slope ?
In book it is 4.65 V
My approach :
as long as the Vi is < 9.3 V , the diode D1 will be ON because in that case VA will be < 10 V and current can flow through 10k resistor. And if this is true then D2 will also be 0N and Vo = Vi.
Now second interval i.e Vi > 9.3 V,  same reasoning for D3 i.e D3 will be ON as long as Vi > -9.3 V & D2 is ON & D4 is also ON. But in this case if we track from input to the output through D3 & D4 , then i get Vo = Vi and this is making D1 ON which i assumed to be OFF. Summarizing my results :
0<Vi<9.3       all diodes are ON & Vo = Vi
Vi>9.3     all diodes are ON & Vo=Vi.....  but this is not possible because this makes VA > 10 which shows current can't flow from +10V battery.    So in short  i know i am doing but the question is where ????
boe
Re: diode circuit
Reply #3 - Oct 29th, 2012, 12:08pm
Aman gupta,
if you can work out what the voltages at nodes A and C are, you should be able to answer the question.
- B O E
