Sep 26th, 2024, 10:16pm
common collector (Read 852 times)
aman gupta
India
common collector
Oct 30th, 2012, 3:08am
for the common collector configuration shown i need to find the voltage gain.
The voltage gain formula is AV = (β+1)(ro ll RE)/(rΠ+(β+1)(ro ll RE)
But in the circuit RE is absent . So how do we consider it ??
Nothing is given about the current source.
from the circuit theory i know that the internal impedance of a current source is very high (am i correct ?).
So in this case how do we relate it ?
raja.cedt
Re: common collector
Reply #1 - Oct 30th, 2012, 5:18pm
hello,
yes you are correct, ideal current  source is infinite resister. So please substitute Re=inf and you get gain=1.
By the way you can explain intutively, due to current source incremental current will be zero, so gm*(Vbe)=0 hence Vbe=0  Vb=Veso unity gain.
Raj.
aman gupta
India
Reply #2 - Oct 30th, 2012, 9:47pm
thanks
Dan Clement
Salt Lake City, Utah, USA
Reply #3 - Oct 31st, 2012, 7:41pm
This is a homework problem from Sedra and smith.
