Sep 26th, 2024, 10:18pm
miller theorem (Read 2532 times)
raja.cedt
miller theorem
Nov 03rd, 2012, 1:18am
Hello all,
i wanted to know miller theorem in bit clear manner. I am aware of miller theorem application to find input impedance, but how about output impedance. Because from output to input gain wont be 1/A (provided A being forward gain in many cases it will be around zero, for example consider common source amp which has good forward gain but very poor reverse gain and this is the essential requirement for an amplifier, then where this theorem at output can be used..
raj.
buddypoor
Bremen, Germany
Re: miller theorem
Reply #1 - Nov 3rd, 2012, 5:34am
Hi Raj,
the Miller-Theorem applies to all networks with an element Z between two nodes, which are (or which should be) referenced to a common point (mostly ground).
This is well explained in Wikipedia and I shouldn`t repeat it here.
More than that, have a look at
http://paginas.fe.up.pt/~fff/eBook/MDA/Teo_Miller.html
raja.cedt
Re: miller theorem
Reply #2 - Nov 3rd, 2012, 6:03am
hello buddypoor,
thanks for the reply.  I know that point, but what i mean is can you tel me some circuit where you can apply at the output? Give some example to me .  For example in the link you gave, after splitting Z between V1 and V2 who will maintain V1/V2 relation?
Raj.
buddypoor
Bremen, Germany
Re: miller theorem
Reply #3 - Nov 3rd, 2012, 6:46am
raja.cedt wrote on Nov 3rd, 2012, 6:03am:
hello buddypoor,
Raj.
As you know, negative feedback drastically reduces the output resistance of opamp circuits.
The reduction factor is (1+T) with T=loop gain magnitude. This is the most illustrative example, for my opinion.
