Sep 26th, 2024, 10:14pm
is this bandpass filter design possible (Read 2653 times)
lhlbluesky_lhl
Nov 05th, 2012, 4:15am
i have to design a bandpass filter with adjustable center frequency f0=20khz, 26khz, 38khz. and for all the three f0, requiring that: Q>10, gain attenuation at 120hz is larger than 80db, gain attenuation at 50khz is larger than 70db. how to realize the bpf circuit? and is it possible?
thanks.
buddypoor
Bremen, Germany
Re: is this bandpass filter design possible
Reply #1 - Nov 6th, 2012, 12:29am
Seems to be not possible (attenuation requirements require unrealistic Q values) according to filter design software.
Question: Is a multi-stage realization allowed? For example: 3 or 4 stages (each of 2nd order).
In this case, you must rewrite the specification and specify the pass band width.
« Last Edit: Nov 6th, 2012, 7:03am by buddypoor »
Sx_cut
Dresden, Germany
Reply #2 - Nov 6th, 2012, 10:38am
Well, I believe there a number of things you need to keep in mind. Firstly which application you are targeting? This will define your specifications. Look back at your specifications!! Then you must decide which methodology you will be following for your filter design. Do you want to make a simple passive filter? Or is it active (op amp and resistors/capacitors), Gm-C type or a switched capacitor (resistors replaced with switches and capacitors in active filters). If you have to make op amp based filters, which transistor technology are you using? BJT, CMOS etc. An excellent reference is chapter 16 of the book "Op amps for everyone" by Texas instruments!!!!! Plz go thru this chapter!
buddypoor
Bremen, Germany
Reply #3 - Nov 6th, 2012, 1:16pm
Sx_cut wrote on Nov 6th, 2012, 10:38am:
...Firstly which application you are targeting? This will define your specifications. Look back at your specifications!! Then you must decide which methodology you will be following for your filter design. ...
For my opinion, the first step is a clear specification. Then, technology and realization aspects are only one of the next steps.
Up to now, the required bandwidth of the passband is unknown (Q>10 says absolutely nothing since a filter order above n=2 will be required).
Reply #4 - Nov 7th, 2012, 1:13pm
ADC followed by a BPF done with a FIR filter in DSP?
One ADC and a pile og DSP logic is smaller and lower power than three analog filters running.
Sigma Delta on the ADC?
