Sep 26th, 2024, 10:21pm
two poles when the opamp in SC configuration? (Read 4952 times)
prcken
PRC
Nov 10th, 2012, 7:56pm
Hi All,
I did
1. opamp open loop simulation, folded cascode with and w/o gain boost
2. put the opamp into multiply-by-two configuration, do pss+pstb analysis, check the gain and unity freq.
3.in the open loop bode plot, DC gain of opamp with and w/o gain boosting is 66.7dB and 44.25dB, respectively. GBW is more than 500MHz and 700MHz, respectively.
4. in the SC configuration, the loop gain drops to 42.45dB and 33.45dB for with and w/o gain boosting, respectively, at 50MHz sampling rate, the GBW drops to ~56MHz and ~45MHz, respectively. seems has two poles there so that the slope falls faster.
I don't know how to add multiple pictures, i will add pictures separately.
AC sim schematic, CL=1.5p
prcken
PRC
Re: two poles when the opamp in SC configuration?
Reply #1 - Nov 10th, 2012, 8:09pm
pstb setup schematic, CL=1.1p, Cf=Cs=0.75p
use cmdmprobe, set CMDM=-1 for checking DM loop stability
in pstb, the gain drops a lot as you can see later. why is that? due to feedback factor?
the plots i got shown later is the cmdmprobe probed at front of CMFB in the opamp schematic.
prcken
PRC
Reply #2 - Nov 10th, 2012, 8:10pm
folded cascode gain-boosted opamp schematic, 3mA current excluding gain-boosting opamps and bias generator.
two CMFB shown, one is ideal CMFB used for AC (continuous time) simulation.
prcken
PRC
Reply #3 - Nov 10th, 2012, 8:17pm
bode plot, open AC sim and loop pstb sim plots.
black line: open AC sim with gain boosting
green: open AC w/o gain-boosting
purple: pstb sim with gain boosting (seem anther pole introduced?)
red: pstb sim w/o gain-boosting
seems opamp put into SC configuration, there have two poles?
I found it's really hard to increase GBW. by hand calculation, i should get 280MHz unity frequency. what I have got it's far less than 280MHz.
in open AC sim, more than 700MHz unity frequency doesn't means anything when i plugged the opamp into the application, why?
thanks!
prcken
PRC
Reply #4 - Nov 10th, 2012, 9:35pm
I found a problem that after i added a pair of switch (yellow circle as i indicated), the result seems good now, enough GBW but smaller PM. as shown in the picture below.
i didn't add that pair of switch is because I intend to do opamp sharing  in the pipeline ADC so that pair of switches will not be there in that case.
even without that switch, the input common mode voltage can still settles to around half vdd, but why it affect the speed that much? that means, when at sampling mode, the opamp has to be in unity feedback configuration?
any comments?
urian
Reply #5 - Nov 14th, 2012, 6:33am
I think the GBW drops because the feedback factor is low. I dont know the arithmetic of pstb how it calculates the PM and GBW, so I dont know why when you add another pair switches, you will get better PM and GBW.
BTW, what's the purpose of NMOS below the input folded PMOS in the amp?
urian
