Sep 26th, 2024, 10:19pm
A charge pump circuit (Read 6191 times)
Yutao Liu
Guangzhou, China
Nov 14th, 2012, 6:45am
Hello everyone,
I found a charge pump topology as shown below.
    The control voltage of VCO is provided by the right-hand-side branch, instead of the left-hand-side. Have you seen this circuitry before? What is it called? I want to do some research on this.
    Furthermore, I think the capacitor C1 still affects the bandwidth of the PLL, even though it is not in the loop directly. Is that right?
Yutao Liu
raja.cedt
Re: A charge pump circuit
Reply #1 - Nov 14th, 2012, 7:13am
hello,
this ckt is wrong. Please find the attached ckt. C1 Has nothing to do with BW, it is just to solve charge injection problem, in principle it is not required.
Raj.
Yutao Liu
Guangzhou, China
Reply #2 - Nov 14th, 2012, 7:25am
Hello Raj,
Thanks for your quick reply.
The ckt in your reply is a classical current steering charge pump.
But why do you think my ckt is wrong?
In my opinion,  the current charging to/discharging from (right branch) the loop filter can represent the phase error all the same.
Yutao Liu
raja.cedt
Reply #3 - Nov 14th, 2012, 7:45am
hello,
Yes in principle your concept doesn't work.
If Up switch turns on C1 connected across bottom current source and at node x no current will flow into loop filter. So no change in the Vctl.
Raj.
Reply #4 - Nov 14th, 2012, 4:02pm
the circuit Raj shows is much more common and probably will work better.
Lex
Eindhoven, Holland
Reply #5 - Nov 15th, 2012, 1:55am
loose-electron wrote on Nov 14th, 2012, 4:02pm:
I agree, but isn't it patented?
raja.cedt
Reply #6 - Nov 15th, 2012, 2:51am
Hello lex,
i guess it is not a patent, in 99% of products you see this circuit. I personally designed around 3 commercial circuits with the same charge pump some minor modification for matching.
raj,
Yutao Liu
Guangzhou, China
Reply #7 - Nov 15th, 2012, 6:14am
Hello raj,
I forgot putting a bias circuit on the ckt. Sorry for my carelessness. The ckt is renew as the attachment. Please check it.
Yutao Liu
raja.cedt
Reply #8 - Nov 15th, 2012, 6:21am
Dear Yutao Liu ,
Problem is not on that side, in fact without bias it would have been better, but problem is other side(loop filter side)
Raj.
Lex
Eindhoven, Holland
Reply #9 - Nov 15th, 2012, 7:30am
raja.cedt wrote on Nov 15th, 2012, 2:51am:
Hello lex,
raj,
Raj,
It looks like the circuit described in: http://www.google.com/patents/US5825640 (figure 7 on page 4 of the PDF)
Reply #10 - Nov 15th, 2012, 8:31pm
that's my definition of a patent that will never stand up in court.
the charge pump in the patent was in wide use 10 years or more prior to the patent.
Lex
Eindhoven, Holland
Reply #11 - Nov 16th, 2012, 1:52am
Hey Jerry,
To be honest I've seen this circuit a few times as well, but I wondered why a company such as Patexia would offer $ 5000 for prior art? Any clue?
« Last Edit: Nov 19th, 2012, 1:28pm by Ken Kundert »
