Sep 26th, 2024, 10:13pm
3.3V vs 14V (Read 2455 times)
grosser
3.3V vs 14V
Nov 20th, 2012, 2:05pm
hello
will it be safe to use 3.3V transistors with 4.2V supply ? Gate oxide breakdown, diode junction breakdown  is 7V and punch through voltage is 6.6V. It is 0.35um process
Or I should use hv transistors ready for 14V?
regards
grosser
boe
Re: 3.3V vs 14V
Reply #1 - Nov 20th, 2012, 2:55pm
Grosser,
this is determined by the reliability of the transistor wrt. hot-electron injection. It does not depend on breakdown or punch-through voltage.
You need reliability data from your fab to answer that; the issue will be most critical for minimum-length transistors
- B O E
analog_wiz
Universe
Re: 3.3V vs 14V
Reply #2 - Nov 20th, 2012, 7:05pm
Hi Grosser, it would depend on the topology you are using.What you can
do it run a transient simulation and measure the voltage across the transistor junctions(eldo has something called reliability simulations...). You could also use ultrasim and it has reliability checks for checking voltages across various junctions and it can flag violations if any when a transient sim is run.
carlgrace
Berkeley, CA
Re: 3.3V vs 14V
Reply #3 - Nov 21st, 2012, 9:21am
The voltage requirements are based on differences between terminals (except for things like well breakdown).
If you don't ever have the 4.2 V across a gate-source or drain-source junction you're golden.  Be sure you carefully check the startup sequence and ESD structures on your chip though... you may need a custom pad (depends on your pad library of course)
Lex
Eindhoven, Holland
Re: 3.3V vs 14V
Reply #4 - Nov 22nd, 2012, 7:57am
carlgrace wrote on Nov 21st, 2012, 9:21am:
If you don't ever have the 4.2 V across a gate-source or drain-source junction you're golden.  ...
I would think that VGS and VGD should not exceed 3.3V, and expect that VDS can handle higher voltages.
