Sep 26th, 2024, 10:13pm
Calculation of minimum number of via: mean, rms or peak current to consider ? (Read 2886 times)
IvoryDesigner
Dec 04th, 2012, 3:19pm
I using a cmos 180nm technology. I have a digital buffer that have 20 mA peak, 0,6 mA average ans 3.8 mA rms.
So I have a general question about which current to use to check the minimum number of via, as the documentation of the design kit give only Jmax (maximum DC current density).
I know the saver way it to consider the maximum, but for density intergration I can't afford it unless it is a must!
Thank you to enlighten me about that point and to share your experience about routing constraint to deal with high AC current.
KC
XY-oriented
Re: Calculation of minimum number of via: mean, rms or peak current to consider ?
Reply #1 - Dec 5th, 2012, 4:55am
one tech I use a lot specify the max current/via for rms values and add that the peak current should not exceed 10 times the rms level.
in your case, since the peak is too high compared to the average (DC ?) I would design for 20mA/10 =2mA
Horror Vacui
Dresden, Germany
Reply #2 - Dec 5th, 2012, 6:21am
Except some extreme cases only the DC current matters, since the effect of AC currents on electromigration is some order of magnitude weaker.
Search for "AC current electromigration" if you want more detail.
IvoryDesigner
Reply #3 - Dec 5th, 2012, 2:10pm
Thank you both for your helpful answers. I will look for "AC current electromigration" for more details.
Best regards !
KC
IvoryDesigner
Reply #4 - Dec 5th, 2012, 3:23pm
Hi here is a good link I found that explain which current to consider depending of the current type (bidirectional or unidirectional):
http://www.masamb.com/EM-IITD.pdf
KC
