Sep 26th, 2024, 8:41pm
how to get the output pulse (Read 936 times)
lhlbluesky_lhl
Dec 06th, 2012, 5:43am
as the picture shows, A is input (T period of burst, T period of idle time, ......), following four divide by 2 circuit, with output B,C,D,E, and rising-edge trigging. i want to get the output as the above waveform shows, that is, after ending of A, B is reset to zero immediately (waiting for next A burst pulse), and after ending of B, C is reset to zero immediately, and so on.
but the actual result is as the below waveform shows, not as i desired.
what should i do to get the above waveform, or how to reset the output to zero immediately after ending of the input?
thanks all.
