Sep 26th, 2024, 10:22pm
stability analysis in active-RC polyphase filter (Read 2368 times)
CMChan
Dec 12th, 2012, 12:37am
I am currently working on a polyphase filter, which is implemented using opamp-RC. The op-amp is written using veriloga with a DC gain of 50 dB and unity gain frequency of 500 MHz. The schematic is shown in Fig. 1.
A cmdmprobe is added in the feedback path of the in-phase opamp and the value of cmdm is set to -1. The obtained loop response is shown in Fig. 2. We can see that when the loop gain phase is 0 at 14.04 MHz, the loop gain is 20.99 dB. It implies an oscillation condition.
The in-phase opamp has a differential feedback loop gain response shown in Fig. 3, when the cross-coupling resistors between I and Q are removed. This loop gain response is easy to understand.
To verify the stability, I added a voltage impulse in one feedback path, shown in Fig. 4. The voltage impulse has both rising and falling slope as 10mV/5ns. The resulted transient response is shown in Fig. 5. We can see that the loop is actually stable.
This design has actually been fabricated and measured. Indeed, there is no oscillation. My question is that why the stability analysis shows that oscillation is possible at 14.04 MHz (zero loop phase and greater than unity loop gain)? Any comment/discussion is appreciated.
Frank Wiedmann
Munich, Germany
Re: stability analysis in active-RC polyphase filter
Reply #1 - Dec 12th, 2012, 1:09am
First of all, the cmdmprobe is obsolete and does not work well if a circuit is not completely symmetric. You should use the diffstbprobe instead.
To simulate the loop gains in this circuit, I would probably first simulate the feedback amplifiers by themselves and verify their stability (as you did).
To examine the complete circuit, I would then place the diffstbprobe in the global feedback path between the amplifiers (in series with the resistors). This treats the amplifiers together with their local feedback as "feedback amplifier units" (that have already been verified for stability).
By putting the probes in the local feedback path while the global feedback is active, you combine the effects from both loops so that the results are very difficult to interpret.
CMChan
Reply #2 - Dec 12th, 2012, 1:56am
Hi Frank, thanks for your quick comment.
Frank Wiedmann wrote on Dec 12th, 2012, 1:09am:
diffstbprobe was introduced in MMSIM10.1. Currently I only have access to MMSIM06.21.431_LNX86, where there is only cmdmprobe.
The amplifier in in-phase path without I/Q cross-coupling has no stability problem, as shown in Fig. 3. Thanks.
Please see Fig. B1 and Fig. B2 for the "global feedback" loop response, where the cmdmprobe was added in the coupling path from I to Q. We can see that the global feedback is stable, as suggested by the PM of 30 deg and GM of 35 dB. So my doubt is that when the global feedback is stable, shall we care about the "local feedback" stability as shown in Fig. 2? Are we supposed to have "absolute" stability in every feedback loop? The simulation of the "local feedback" loop response should be correct. I derived the local feedback loop response and obtained the bode plot using matlab, which is close to Cadence stability results.
Is the "local feedback instability" a special phenomenon for polyphase filter and can be ignored?
Thank you.
Frank Wiedmann
Munich, Germany
Reply #3 - Dec 12th, 2012, 6:59am
When the global feedback is active, what you call local feedback is really a combination of local and global feedback. This often gives rather unusual results for the loop gain which can no longer be analyzed with the simplified rules of phase margin or gain margin. You can find a discussion about the significance of phase margin at http://groups.yahoo.com/group/Design-Oriented_Analysis_D-OA/message/45 (you probably should read the entire thread to understand the context).
Instead, you should examine your loop gain from Fig. 2 with the Nyquist stability criterion (see http://en.wikipedia.org/wiki/Nyquist_stability_criterion) that is valid in all cases. According to this criterion, your circuit must be stable. Please also note that the loop gain phase reported by the stb analysis has a difference of 180 degrees with respect to most other definitions (see http://www.designers-guide.org/Forum/YaBB.pl?num=1124688329).
However, I believe that the approach I described in my last response is sufficient and that you don't really need to examine the loop gain from Fig. 2.
nrk1
Reply #4 - Dec 12th, 2012, 7:52am
CMChan wrote on Dec 12th, 2012, 12:37am:
I am that oscillation is possible at 14.04 MHz (zero loop phase and greater than unity loop gain)? Any comment/discussion is appreciated.
Zero loop gain phase and greater than unity loop gain magnitude does not mean instability. That would be true where the loop gain has only poles and no zeros.
CMChan
Reply #5 - Dec 12th, 2012, 7:40pm
Frank Wiedmann wrote on Dec 12th, 2012, 6:59am:
Thanks for the info. Yes, I agree that the "local feedback" I referred is actually a combined effect of local and global feedback. I will go through the detail regarding the stability margin and run the simulation using LT-spice.
I will check using Nyquist stability criterion as well.
Assuming feed forward transfer function as A and feedback as B, the Cadence calculate -AB as the loop gain response. The minus sign stems from the negative feedback.
CMChan
Reply #6 - Dec 12th, 2012, 7:46pm
nrk1 wrote on Dec 12th, 2012, 7:52am:
Assuming the op-amp differential feedback resistor as Rlp and differential feedback capacitor as Clp. There are two zeros at low frequencies: one at 1/(2*pi*Rlp*Clp) and another is close to the first one. Due to negative feedback, the loop gain phase increases from -180 deg. Yes, the point at 14.04 MHz in Fig. 2 is mostly contributed by the two zeros. Thanks.
Frank Wiedmann
Munich, Germany
Reply #7 - Dec 13th, 2012, 12:58am
And just in case you have not already discovered it: you can find very extensive information about loop gain simulation in general on my webpage https://sites.google.com/site/frankwiedmann/loopgain.
