Apr 16th, 2024, 8:49am
how to create config view and simulate verilog-AMS code (Read 93 times)
susona
Aug 15th, 2013, 3:55am
hai all
I am new to use AMS. presently we equipped with Cadence IC614 dfII enivronment. i wanted to code SAR ADC in verilog-AMS so before that i just taken the verilog-AMS code listing 12 from this forum and try to simulate it but i am getting errors in the simulation.
i used ADE and try to simulate then also i am getting the errors so can any one tell me how to run verilog-AMS code and test bench using virtuoso ADE
the other thing is can we attach verilog-ams to a technology file like 65nm or 180nm technology
how to get the power estimation from the verilog-AMS code
i am reading the help notes and trying but not able to solve errors if any one can help thanks in advance
Susona
susona
Re: how to create config view and simulate verilog-AMS code
Reply #1 - Aug 15th, 2013, 9:06pm
please some body reply me how to do that
visbi
Bay area,SF
Reply #2 - Aug 19th, 2013, 3:40pm
First create the schematic (any other view) from Library Manger. Then in the same file again create config view and select Hierarchy in Open with.
Then use the template of AMS. In view select the schematic.
Visbi
Always in hurry
susona
Reply #3 - Aug 19th, 2013, 8:24pm
can you explain how to attach technolgy file to verilog -ams code and also to calulate the power consumption for the behavioral verilog-ams code
Reply #4 - Nov 9th, 2013, 4:22am
Susona,
  When creating library for a purely behavioral modeling purposes,
a technology file is not required. You can select none.
girishnani
Reply #5 - May 1st, 2014, 2:48am
hello, i have done all these steps config. and everything.. i was strucked at connecting rules when i add ams setup it doesn;'t show any connecting rules. how to add connecting rules. without those rules it is showing error. please help me.
boe
Reply #6 - May 7th, 2014, 8:16am
Girishnani,
you should start with reading the relevant tutorials. The connect rules should be installed and included in the lib list.
- B O E
