Apr 19th, 2024, 3:28am
PDK Transfer (Read 237 times)
KRAHASS
PDK Transfer
Sep 16th, 2013, 1:07am
Dear all,
Do you know if on Cadence EDA tools it is possible to transfer a design from one technology to another and keeping component parameters inchanged. I mean if I did a design in one technology, is it possible to keep the same design (without retyping schamatic and layout) when I change the technology.
KRAHASS
nat
Warsaw
Re: PDK Transfer
Reply #1 - Sep 19th, 2013, 2:55am
It does not have that functionality built-in. If you talk about schematic porting you could use a 3rd party software, MunEDA has schematic porting tool.
I've developed skill scripts which have done this as well, but it is not so trivial.
If the technology is REALLY similar you could port some layout too. Friend of mine has done this using mentor's calibre.
KRAHASS
Re: PDK Transfer
Reply #2 - Sep 19th, 2013, 3:28am
Hi nat,
Thanks for answering. Yes I'm talking about schematic porting and also layout porting, I know it's quite difficult to do this latter task especially when technologies are different but I want to find an efficient way, time saving also to transfer design from one techno to another. I took a look on MunEDA website but I didn't find something about layout porting. Your friend have done this on the same techno? I mean the same foundry? What do you think if fabs and EDA tools are different at the same time? this could be an impossible task since the scripting language for PCells are different most often, isn't?
nat
Warsaw
Re: PDK Transfer
Reply #3 - Sep 19th, 2013, 4:06am
MunEDA has tool for schematic porting only.
At first he has done this layout porting in the same foundry process, the same node size even just between different "flavors" (RF, low leakage, high voltage variants).
But later we have port some to other foundries and node sizes (to smaller)  as well.
As of efficient way, I've heard about some company approach which developed it's own set of rigorous layout rules and masks, do the layout in this custom technology, and then by applying some set of transformations, print layout to the target technology
KRAHASS
Re: PDK Transfer
Reply #4 - Sep 19th, 2013, 4:22am
OK. Layout porting in the same foundry process seems to be more easier. Could you please post some guidelines, tutorials for the second case (different fabs). I found some companies that are doing PDK migration/Layout porting, here is references: http://sagantec.com, http://www.in2fab.com.
About the company approach, I didn't understand well the strategie but if you have some references as well as guidelines, do not hesitate to post them, it can may be help other designers. Thank you in advance.
Krahass
nat
Warsaw
Re: PDK Transfer
Reply #5 - Sep 19th, 2013, 6:35am
Not really, as far as I know there are no such texts (tutorials etc).
What can I say is that porting  was done (both cases) useing Mentor Calibre. Friend of mine developed custom DRC (I think it was drc) deck that performed necessary layers transformation. The only help he used was Calibre documentation and process layout rules.
For the second strategy: It's just the thing I've heard. This company created it's own custom PDK (but only for layout drawing). They choosed their own drc rules and did all the layout in this custom pdk. Then the final step was to apply some transformation rules (something similar to our case) to change layout from this custom pdk to the foundry pdk.
So they were drawing just 1 layout, and develop as many as they needed transformation scripts  to quickly port their project.
PS I don't have any experience with automatic layout porting tools
KRAHASS
Re: PDK Transfer
Reply #6 - Sep 19th, 2013, 6:50am
OK. Thanks for these informations. Anyway, I think that the task seems to be quite complicated.
nat
Warsaw
Re: PDK Transfer
Reply #7 - Sep 19th, 2013, 8:44am
It is complicated:)
Personally I am more of a layout automation guy than technology transfer. If you are using Cadence take a look at its modgen and it  auto routing capabilities.
KRAHASS
Re: PDK Transfer
Reply #8 - Sep 20th, 2013, 4:34am
Here is an interesting paper dealing with schematic and layout migration, This success story demonstrates how complicated and time-consuming the task is. Enjoy and share if you're facing the same issue.
krahass
Paper link: http://sagantec.com/html/analoghardip.pdf
