Mar 27th, 2023, 1:08am
Measure noise of Switched-capacitor amplifier. (Read 5767 times)
Jacki
Nov 23rd, 2013, 10:22am
   Now I plan to measure the noise of a switched-capacitor amplifier with Agilent PSA series spectrum analyzer E4445A. Is it straightforward to measure the noise? I am thinking some examples here.
   Example 1: step 1. Turn on the signal generator, measure the gain
step 2. Turn off the signal generator, measure the noise at the output.
step 3. Calculate the input referred noise based on the output noise and gain.
   Is it correct?
   Example 2: step 1. Turn off the signal generator, measure the noise at the output.
step 2. Add a noise source, measure the noise at the output (set the gain of SC-amp to 0dB).
step 3. Calculate the noise.
   In spectre simulation, usually I use PNoise to simulate the noise of SC-circuits. Can I get the same results when I use spectrum analyzer to measure the chip compared with the PNoise simulation?
   Any comments for the noise measure of SC-circuits are appreciated.
   Jacki
Jacki
Re: Measure noise of Switched-capacitor amplifier.
Reply #1 - Nov 25th, 2013, 9:06am
I wonder if the PNoise in the simulation can display the similar results as spectrum analyzer in the measurement.
Jacki.
Reply #2 - Nov 25th, 2013, 4:20pm
Yes, of course. A spectrum analyzer measures the time-averaged noise. In SpectreRF PNoise analysis direct plot form, this is referred to as "Sources" (I don't know why it is called Sources, but it is). SpectreRF's effective noise bandwidth is 1Hz.
Jacki
Reply #3 - Nov 26th, 2013, 2:02am
Thank you very much, Ken. I think I need to use the bandwidth of 10Hz in the spectrum analyzer, but it is really slow, then use the equation to calculate the noise at 1Hz bandwidth.
Jacki.
Reply #4 - Dec 27th, 2013, 1:51pm
Ken Kundert wrote on Nov 25th, 2013, 4:20pm:
Ken,
I assume this is because it was originally either outputting the noise source information, or the cross-power densities (from "spectre -h pnoise"). I assume the parameter got hijacked to be the mode of operation (hence it now supports timedomain and pmjitter), and so the original meaning is a bit mixed up (I think this happened in something like IC445, which is when timedomain noise was introduced). Probably seemed like a good idea at the time  ;)
