dog1
Hi guys, I am simulating an LNA at 60GHz and need some inductors there. And I need to incorporate the couplings between the inductors and other structures. However, I don't know if there is a way to incorporate the effect of the guardring in the simulation when dealing with those couplings. Right now, I mostly use momentum for the simulation of large metal structures like inductors, but the effect of the guarding ring in the substrate can not be taken into consideration there. And also in the process I uses a lower metal shielding is not recommended, thus the effect of the guarding ring is very important.
Thanks!
