Christoforos
Hello!
I am modelling the decimation filter after a Sigma-Delta converter in MATLAB using the signal processing toolbox. The passband frequency is 10 Hz and the downsampling ratio is 512. As a decimation filter I am using the Hogenauer CIC filter. The filter is stable up to and including the 3rd order. From 4th order is becomes unstable. Also, when I look at teh zplane the poles of the filter are just outside or the unit circle. Can someone help me to fix this?
Thank you!
