Apr 24th, 2024, 12:01pm
Variable duty cycle clock generation (Read 3464 times)
rf_1
Sep 05th, 2014, 8:56am
I am trying to do a "Verilog - A " model of a block which takes in a control voltage (duty cycle = d ) and a 50% duty cycle clock. as input. The output of this block is a clock with duty cycle 'd'.
I am not able to figure out how to go ahead with this problem.
I have looked into the following post
http://www.designers-guide.org/Forum/YaBB.pl?num=1138941612/15
Please advise
Re: Variable duty cycle clock generation
Reply #1 - Oct 20th, 2014, 4:39pm
integrate the square wave - gives you a triangle wave
use the duty cycle value to set a comparison level.
switch states when the two signals equal in value.
