Mar 29th, 2024, 12:54am
How to make a 1:4 demux in VAMS (Read 1802 times)
wag_master
Colorado Springs, CO
Sep 23rd, 2014, 3:05pm
I need a 1:4 demux model (data distributor). The following code doesn't work because the transition statements are in a conditional. Does anyone know how this can be done?
Thanks.
module muxdr_1_4(Dp, Dn, Rp, Rn, CKp, CKn, D0p, D0n, D1p, D1n, D2p, D2n, D3p, D3n, vcc);
     input Dp, Dn, Rp, Rn, CKp, CKn, vcc;
     voltage Dp, Dn, Rp, Rn, CKp, CKn, vcc;
     output D0p, D0n, D1p, D1n, D2p, D2n, D3p, D3n;
     electrical D0p, D0n, D1p, D1n, D2p, D2n, D3p, D3n;
     parameter real vswing = 0.24 from (0:inf);
     parameter real tdel = 5p from [0:inf);
     parameter real trise = 10p from (0:inf);
     parameter real tfall = 10p from (0:inf);
     real out0p, out0n. out1p, out1n, out2p, out2n, out3p, out3n;
     integer x, cntr;
     analog begin
           @(initial_step) begin
                 cntr = 0;
           if (V(Rp) > V(Rn))
                 cntr = 0;
           @(cross( V(CKp)-V(CKn), 1 ) ) begin
                 cntr = cntr+1;
                 if (cntr > 3)
                       cntr = 0
           x = V(Dp) < V(Dn);
           outp = V(vcc)*x + (V(vcc)-vswing) * !x;
           outn = V(vcc)*!x + (V(vcc)-vswing) * x;
           case (cntr)
                 0:      begin
                       V(D0p) <+ transition( outp, tdel, trise, tfall);
                       V(D0n) <+ transition( outn, tdel, trise, tfall);
                 1:      begin
                       V(D1p) <+ transition( outp, tdel, trise, tfall);
                       V(D1n) <+ transition( outn, tdel, trise, tfall);
                 2:      begin
                       V(D2p) <+ transition( outp, tdel, trise, tfall);
                       V(D2n) <+ transition( outn, tdel, trise, tfall);
                 3:      begin
                       V(D3p) <+ transition( outp, tdel, trise, tfall);
                       V(D3n) <+ transition( outn, tdel, trise, tfall);
                 default:
                       $strobe("muxdr_1_4: Help! cntr = %d", cntr);
           endcase
Re: How to make a 1:4 demux in VAMS
Reply #1 - Sep 23rd, 2014, 8:28pm
All the signals other than the supplies appear as if they are digital signals. You claim to want a Verilog-AMS model, but you gave a Verilog-A model. If the model is digital, you should be using Verilog.
wag_master
Reply #2 - Sep 24th, 2014, 7:43am
It needs to be Verilog-A or AMS because the output needs to be Vcc referenced with a 240 mV swing.
I thought AMS was a super-set of Verilog-A?
Reply #3 - Sep 24th, 2014, 8:26am
Using Verilog-A for digital signals is slow and tedious. You are better served writing a Verilog model, and then if you need an electrical output, just modifying it so that it produces it.
However, if you want to continue to use Verilog-A, you can simply assign to variables in the case statement, and drive the outputs using a transition function applied to the variables outside any conditionals.
wag_master
Reply #4 - Sep 24th, 2014, 12:03pm
Ken:
The problem with that is that the output which gets the transition depends on cntr. How is that done? Do you assign a variable for each output like this: out1p = V(D0p) and so on for all 8 outputs, then use a case statement to change the one that is selected. and then have 8 transition statements after the case?
Maybe it would be easier to do what you said- Verilog then convert. That would be done external to the Verilog code?
wag_master
Reply #5 - Sep 25th, 2014, 8:44am
Putting it in Verilog sort of makes things more difficult. It'd need to make a Verilog cell for each function I want to model, then put that inside another cell to convert it from logic to analog. And convert analog to logic at the input.
I guess I'd really like to stay with Verilog-A/AMS....
Reply #6 - Sep 25th, 2014, 8:24pm
There is only one function you want to model, and that is your dmux, so there is no need for multiple cells. I do not understand your issue with using verilog-code for most of the model.
If you want stick with Verilog-A, you can use 4 variables, and convert to differential signals only when driving the outputs.
wag_master
Reply #7 - Sep 26th, 2014, 1:39pm
Ken:
I am developing a behavioral simulation which will eventually be transistor level and use the same cells and symbols. So it would be nice to stay analog and use the same simulator.
I have several other functions I need to model, but the Verilog-A is working for those, so you're right, I only have one function left to model. The reason I'd use two cells is I'd put the Verilog cell inside another cell that would also have the circuits (VCVS) that would convert analog to digital and back. Essentially CML to CMOS and vice versa.
Tom
wag_master
Reply #8 - Sep 26th, 2014, 3:30pm
I got it working. Here's the code:
`include "discipline.h"
`include "constants.h"
// demuxdr_1_4
// V1. 9/23/2014 TS
//            Added reset, made all pins differential except vcc.
//            Logic is vcc referenced with a pp swing of vswing
// -  1 to 4 demux
//            This models an active demux, not a t-gate type.
//            It uses an internal counter instead of external inputs
//            to determine which output is selected.
// Dp, Dn:                  Signal to be multiplexed (val)
// CKp, CKn:            Clock input (val)
// Rp, Rn, Sp, Sn:      Reset and set inputs (val)
// Q0,Q1,Q2,Q3:            Outputs (val,flow)
// vcc:                        Supply voltage (val)
// INSTANCE parameters
//    vswing = p-p output voltage swing
//        tdel, trise, tfall = the usual [s]
module demuxdr_1_4(Dp, Dn, Rp, Rn, CKp, CKn, Q0p, Q0n, Q1p, Q1n, Q2p, Q2n, Q3p, Q3n, vcc);
     output Q0p, Q0n, Q1p, Q1n, Q2p, Q2n, Q3p, Q3n;
     electrical Q0p, Q0n, Q1p, Q1n, Q2p, Q2n, Q3p, Q3n;
     real out0p, out0n, out1p, out1n, out2p, out2n, out3p, out3n;
     real vh, vl;
     integer x, x0, x1, x2, x3, cntr;
     analog begin
                 // Since cntr=cntr+1 occurs before the case statement,
                 // this makes the first one selected to be out0.
                 cntr = 3;
                 vh = V(vcc);
                 vl = vh-vswing;
                 out0p = vl;
                 out1p = vl;
                 out2p = vl;
                 out3p = vl;
                 out0n = vh;
                 out1n = vh;
                 out2n = vh;
                 out3n = vh;
           if (V(Rp) > V(Rn))
                 cntr = 3;
                 cntr = cntr+1;
                 if (cntr > 3)
                       cntr = 0;
                 x = V(Dp) > V(Dn);
                 vh = V(vcc);
                 vl = vh-vswing;
                 // Do the demux function
                 case (cntr)
                       0:      begin
                                   out0p= vh*x + vl*!x;
                                   out0n= vh*!x + vl*x;
                                   $strobe("%r: Setting out0", $abstime);
                       1:      begin
                                   out1p= vh*x + vl*!x;
                                   out1n= vh*!x + vl*x;
                                   $strobe("%r: Setting out1", $abstime);
                       2:      begin
                                   out2p= vh*x + vl*!x;
                                   out2n= vh*!x + vl*x;
                                   $strobe("%r: Setting out2", $abstime);
                       3:      begin
                                   out3p= vh*x + vl*!x;
                                   out3n= vh*!x + vl*x;
                                   $strobe("%r: Setting out3", $abstime);
                       default:
                             $strobe("%r: ***** demuxdr_1_4: Help! cntr = %d", $abstime, cntr);
                 endcase
           V(Q0p) <+ transition( out0p, tdel, trise, tfall);
           V(Q0n) <+ transition( out0n, tdel, trise, tfall);
           V(Q1p) <+ transition( out1p, tdel, trise, tfall);
           V(Q1n) <+ transition( out1n, tdel, trise, tfall);
           V(Q2p) <+ transition( out2p, tdel, trise, tfall);
           V(Q2n) <+ transition( out2n, tdel, trise, tfall);
           V(Q3p) <+ transition( out3p, tdel, trise, tfall);
           V(Q3n) <+ transition( out3n, tdel, trise, tfall);
