jsaenznoval
Hi Jerry,
This open drain switch is to be integrated so it won't be implemented using discrete transistors. My question comes from the fact that lateral MOSFET occupies more area than vertical counterparts in the process that I'm using. Additionally, the vertical MOSFET layout is symmetric. I want to know the differences between a lateral and vertical MOSFET and which I should be selected for my application, which is basically and on/off open-drain switch with a 1024ms pulse duration. From my point of view, I can perfectly use a vertical MOS because due application uses low frequency and switching performance doesn't matter. Thanks!
What is your opinion?
