Apr 25th, 2024, 4:14am
overbar for inverted pin name (Read 4890 times)
Shahriar
Chelsmford, MA
Feb 26th, 2015, 8:53am
I'm not sure if this is the right forum to ask this question. Is there any way to create a pin name with overbar in schematic and layout? For example, if I an inverter cell with input A, I want the output name to be A with a bar over it (NOT A).
Thanks in advance.
Shahriar
View Profile Shahriar   IP Logged
boe
Re: overbar for inverted pin name
Reply #1 - Feb 28th, 2015, 3:45am
Shahriar,
using which tool?
- B O E
Shahriar
Chelsmford, MA
Reply #2 - Mar 1st, 2015, 1:36am
I'm using cadence ic614. I'm trying to create a schematic symbol Where I want to make a pin with inverted logic. I have to do the same in the corresponding layout, too.it
Shahriar
boe
Reply #3 - Mar 4th, 2015, 11:21pm
Shahriar,
the object property dialog allows you to enable "Overbar" for labels.
If you enable this, "_name_" is shown as "name" with overbar.
- B O E
