Nov 7th, 2026, 9:04pm
calibre pex problem (Read 4555 times)
wang072711
calibre pex problem
Mar 13th, 2015, 8:47am
I generated the layout using encounter.
Passed DRC and LVS in cadence virtuoso.
Things went wrong when I extracted the layout and running post-simualtion.
Then I checked the extracted calibre view schematic. there are floating nets for some PMOS and NMOS.
I tried with different extraction type. when I using C+CC or NO R/C
for PEX, there are no problem. Post-sims give the correct waveforms
But when I extracted with R. things went wrong.
I also tried a smaller design with only Four logic gates, and make sure that the routing is very short. Still the same problem
Also tried to exclude the parasitics from the power line. didn't work.
Any suggestion why or how to debug this?
thank you so much!!
wang072711
Re: calibre pex problem
Reply #1 - Mar 13th, 2015, 8:49am
And I'm sure those floating net is wrong. I checked the netlist manually those floating nets should be connected.
