Raghu9685
Hi ULPAnalog
Yes It is single ended output structure. both label are not same one are "out" and another one is "out-" . I tried both the cases first I given the single output of amp to anti-chopper circuit not getting result so I also tried that double ended output to anti-chopper circuit then also I am not getting result.
Thanks & Regards Raghu
