Mar 29th, 2024, 3:16am
Checking for stability in a bang bang CDR (Read 5474 times)
Venky_analog
Analog Design is my
trade. Math is my
love.
TX, USA
Nov 18th, 2015, 11:46pm
I am working on a bang-bang CDR. There is one thing that's bothering me a lot. How to check for stability of this CDR, as bang-bang PD is a non-linear element. I read this paper by Ken Smiley
"Analysis and Modeling of Bang-Bang Clock and Data Recovery Circuits"
I can understand the approximate expressions for Jitter Transfer Function, Jitter Tolerance etc. but I couldn't find out how to actually check for the stability of this CDR loop. Since this is a non-linear element, how would we define the damping factor or closed loop poles or phase margin in such systems?
I will be really happy if someone could tell me how to check for stability (or design for good phase margin) in a bang-bang CDR. Thanks in advance.
Either die a white noise or live long enough to see yourself become the 1/f noise.
raja.cedt
Re: Checking for stability in a bang bang CDR
Reply #1 - Nov 19th, 2015, 12:23am
Hello--
Yes Bang-bang phase detector is non-linear hence, linearized model can be used when phase error close to 0 (that's where it locks any way).This has been derived based on distribution of input jitter.
Phase detector gain---For random jitter---0.399/Sigma.
                           ---For uniform distribution---0.288/Sigma.
Get the rest of the Z-domain transfer functions like loop filter,Phase interpolator(or VCO), loop delay and plot the transfer functions. You will see loop bandwidth and closed loop peaking.
refer the following pap---
A Digital Clock and Data Recovery Architecture
for Multi-Gigabit/s Binary Links
Raj.
Venky_analog
Analog Design is my
trade. Math is my
love.
TX, USA
Reply #2 - Nov 19th, 2015, 9:26am
Thank you very much for replying.
There is one thing that's bothering me.
Bang-bang PD is linear over a very small difference in phase. How can we check stability of the complete system by assuming the linearized model. Even a small signal would make it move to non-linear region and I don't know what will happen to the stability of the loop when that happens.
By the way, I am implementing an analog loop filter and not digital.
Thanks in advance.
raja.cedt
Reply #3 - Nov 20th, 2015, 3:30am
Hello--
Yes that's true, it is hard non-linear circuit. That's why full transistor simulation and behavioural model sim gives full picture of stability at the cost of Sim time. I did few years back the same and results not close but good enough for any traditional CDR, but some how I saw better high frequency jitter tolerance compared to small signal model. Fortunately when the bandwidth is very less compared to data rate rate(~1/5000-2000) stability always looks good due to lower update rate.
Raj.
BackerShu
Reply #4 - Jan 17th, 2016, 2:08am
If you are really interested, pleases read Jaeha Kim PhD thesis, Starting from Page 143. He treated it as bang-bang controlled loop, which is common in control theory. It is a nice reading.
