hello
while doing pnoise simulation,i have no idea of how to set the maxside band, and how to choose the option of "jitter mode" or "source mode"?
now, i have some views on the two problems above
1. if beat frequency is 5G, while i want to check 1M~15GHz Random jitter,
so the pnoise simualtion frequency integration range is 1M~2.5G, and the max sideband is (15G-2.5G)/2.5G=5
2. if doing driven circuit(buffer chain,divider,pfd...) pnoise simulation should choose "jitter mode"
if doing autonoumous circuit(vco...)pnoise simulation should choose"source mode"
3. BTW,what is the relationship of "jitter mode" and "source mode" with FM/PM noise option?
appriatiate for your kindly answer
