Nov 7th, 2026, 9:20am
a error about the 'always' process of verilog-a (Read 4329 times)
Big Data
Jan 19th, 2016, 8:06am
does anyone know how to solve this error?(i'm using hspice2010):
pvaE* Not support Verilog-D syntax!!! 'always'
     file "adc.va", line# 14
always @(posedge clk)begin
Re: a error about the 'always' process of verilog-a
Reply #1 - Jan 19th, 2016, 10:04am
always is part of Verilog-AMS (or digital Verilog); it is not supported in Verilog-A.
You could try using the cross event
 @(cross(V(clk) - vth)) begin
AMS_ei
Reply #2 - Aug 6th, 2016, 6:43am
you can also use @(above(expr)) statement.
Thanks.
