Apr 25th, 2024, 5:50am
what are second order terms in undersampling (Read 2425 times)
jovial
Feb 4th, 2016, 9:06am
hello all !!!
I am reading Filter Basics: Anti-Aliasing, a tutorial by Maxim.
I am confused in the section of undersampling.
I am attaching the image of the pdf of the section where I am confused.
The tutorial says "Undersampling at 4MHz yields first-order sum and difference terms (f1 + f2 and f1 - f2) of 14MHz and 6Mz, and second-order terms (2f1, 2f2, 2f1 + f2, f1 + 2f2, | 2f1 - f2 |, | f1 - 2f2) | of 8MHz, 20MHz, 18MHz, 2MHz, 24MHz, and 16MHz. "
I am OK with the "first-order sum and difference terms".
I am confused as to how to justify the second order terms? where do they come from? any formula/expresssion? any book or website is welcome.
« Last Edit: Feb 04th, 2016, 2:45pm by Forum Administrator »
deba
Re: what are second order terms in undersampling
Reply #1 - Oct 15th, 2016, 12:23am
The Fig 3(a) and Fig 3(b) explain the undersampling phenomenon quite well. Any frequency compnonent at f1+/-n*f2, when sampled at f2 will appear as f1 in the sampled domain.
where f1 is the input signal, n is an integer and f2 is the sampling frequency.
