Apr 25th, 2024, 9:50am
Generating Verilog netlist from Schematic in IC61 using NC-Verilog (Read 1080 times)
ic_engr
Jun 16th, 2016, 9:23am
Hello
I am trying to generate Verilog netlist from schematic in IC 6.1 using NC-Verilog.
I am getting the following errors:
*Error* evalalias: a macro must be defined before its use - (hnlSetOutputVars)
In the Netlist Set-up I am setting stop view as "symbol" since I dont want it to netlist transistors.
Any idea what may be causing this.
ic_engr
Re: Generating Verilog netlist from Schematic in IC61 using NC-Verilog
Reply #1 - Dec 29th, 2016, 2:07am
This was a bug which was fixed in IC617, and happened if you used ADE first and then the Verilog netlister later within the same session. See https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000005xHB5EAM&p...
Andrew
