Oct 12th, 2026, 2:28pm
[SOLVED] oneshot circuit or monostable multivibrator (Read 5543 times)
Shahriar
Chelsmford, MA
Sep 29th, 2016, 11:23am
I'm new to veriloga. I'm trying to make a veriloga model for a one-shot circuit. The steady output will be low. It would trigger on both positive and negative edges of input and the output will stay high for a defined "pw" parameter.
I can't figure out how to code the output getting back to steady state after "pw" time has passed after an edge occurs in input.
Here's the code I've written so far.
// VerilogA for scratch_veriloga, oneshot, veriloga
`include "constants.vams"
`include "disciplines.vams"
module oneshot (trigger, oneshot);
input trigger;
output oneshot;
voltage trigger, oneshot;
parameter real vil = 0.5;
parameter real vih = 2;
parameter real thres = (vil+vih)/2;
parameter real vol = 0;
parameter real voh = 2.5;
parameter real td = 0.1n from [0:inf);
parameter real tt = 0.1n from [0:inf);
parameter real pw = 3u from [0:inf);
//parameter integer dir = +1 from [-1:+1] exclude 0;
real state;
analog begin
	@(cross(V(trigger)-thres)) state = 1;
	//can't figure out how to code that 'state' will go back to 0 after 'pw' time after cross event.
	V(oneshot) <+ transition(state?voh:vol,td,tt);
Could anyone please tell me how I can do this? Or point me to an example?
Thanks.
« Last Edit: Sep 30th, 2016, 9:57am by Shahriar »
Shahriar
View Profile Shahriar   IP Logged
Shahriar
Chelsmford, MA
Re: oneshot circuit or monostable multivibrator
Reply #1 - Sep 30th, 2016, 9:56am
Found the solution myself here. http://www.designers-guide.org/Forum/YaBB.pl?num=1210828245
@(cross(V(trigger)-thres)) begin
		state = 1;
		next = $abstime + pw;
	@(timer(next)) state = 0;
Shahriar
Re: [SOLVED] oneshot circuit or monostable multivibrator
Reply #2 - Oct 1st, 2016, 5:00pm
Thanks for posting your solution.
