Apr 23rd, 2024, 12:40pm
ams simulator timing problem (Read 2193 times)
liletian
MD
Oct 06th, 2016, 11:51am
Hi All
I am trying to speed up the ams simulator by using behavior model. However, the behavior model does not generate correct results. It seems to due to the timing problem. It used to have some .libs for ams simulator, but right now I only have fixed rising, falling time and delay in the behavior model. Can anyone comments on how to solve this problem?
The timing violation looks like this
Warning! Timing violation
$setuphold<setup>( posedge CK &&& (flag == 1):209850883146 FS, negedge D:209850830504 FS, 1.000 : 1 NS, 0.500 : 500 PS );
File:DFFRHQX1/functional/verilog.v, line = 44
\instClash_reg_address_reg[4]
Time: 209850883146 FS
tran: time = 210 us (55.3 %), step = 72.47 ps (19.1 u%)
tran: time = 210.1 us (55.3 %), step = 83.37 ps (21.9 u%)
tran: time = 210.2 us (55.3 %), step = 16.21 ps (4.27 u%)
tran: time = 210.6 us (55.4 %), step = 83.96 ps (22.1 u%)
tran: time = 210.7 us (55.5 %), step = 154.7 ps (40.7 u%)
tran: time = 210.9 us (55.5 %), step = 10.79 ps (2.84 u%)
tran: time = 211 us (55.5 %), step = 77.62 ps (20.4 u%)
$setuphold<setup>( posedge CK &&& (flag == 1):211043873290 FS, negedge D:211043830474 FS, 1.000 : 1 NS, 0.500 : 500 PS );
File:
/DFFRHQX1/functional/verilog.v, line = 44
Scope: instClash_reg_address_reg[4]
Time: 211043873290 FS
tran: time = 211.1 us (55.6 %), step = 137.8 ps (36.3 u%)
tran: time = 211.3 us (55.6 %), step = 73.09 ps (19.2 u%)
tran: time = 211.4 us (55.6 %), step = 136 ps (35.8 u%)
tran: time = 211.8 us (55.7 %), step = 160.5 ps (42.2 u%)
tran: time = 211.9 us (55.8 %), step = 63.67 ps (16.8 u%)
tran: time = 212 us (55.8 %), step = 30.07 ps (7.91 u%)
tran: time = 212.2 us (55.8 %), step = 541.7 ps (143 u%)
$setuphold<setup>( posedge CK &&& (flag == 1):212236883152 FS, negedge D:212236830468 FS, 1.000 : 1 NS, 0.500 : 500 PS );
File: /DFFRHQX1/functional/verilog.v, line = 44
Time: 212236883152 FS
AMS_ei
Re: ams simulator timing problem
Reply #1 - Apr 19th, 2017, 9:16am
One thing I can suggest is that delay must be annotated to 100%.
Could you please check the annotation statistics if it is 100%?
Hope this helps.
Thank you.
Kind regards
