Apr 24th, 2024, 6:01pm
Effective length of capacitance in less than or equal to zero (Cadence Spectre) (Read 4183 times)
Estimulo
Oct 29th, 2016, 1:00am
Hello Everyone,
While simulating a design of 3:8 decoder, spectre is producing an error as :
Error found by spectre during initial setup.
   ERROR (CMI-2215): I0.I6.I0.M1: The effective length of capacitance is less than or equal to zero.
I have tried changing width of M1 and transistors present in instances I0 and I6.
Please tell me, how can it be resolved.
« Last Edit: Oct 29th, 2016, 3:15am by Estimulo »
Re: Effective length of capacitance in less than or equal to zero (Cadence Spectre)
Reply #1 - Oct 31st, 2016, 10:47am
I think there's something wrong with your setup.  You shouldn't be getting those warnings about "'nf' is not a valid parameter"
I wonder if you're using a netlist from one PDK with a model library from another PDK.
Abhi_iitm
Reply #2 - Jun 2nd, 2018, 5:27am
Hey i am facing the exact same issue with the same library ,
could someone please help?
Abhi_iitm
Reply #3 - Jun 2nd, 2018, 5:28am
Geoffrey_Coram wrote on Oct 31st, 2016, 10:47am:
I am facing the same issue though i am using the pdk for the same library
kindly help,
Reply #4 - Jun 2nd, 2018, 6:45am
It would help somewhat if you said which PDK (and models) you were using - info such as the foundry, process node, and ideally any version number for the PDK or model files.
That will significantly increase the chance of somebody being able to help you.
Abhi_iitm
Reply #5 - Jun 2nd, 2018, 6:57am
it is UMC_18_CMOS
These are the directory details indicating exact model:
G-9FD-MIXED_MODE_RFCMOS18-1.8V_3.3V-1P6M-MMC_ \
UM180FDKMFC00000OA-FDK-Ver.A02_PB \
/UM180FDKMFC00000OA_A02_DESIGNKIT \
/UM180FDKMFC00000OA_A02_PB/UMC_18_CMOS
Reply #6 - Jun 4th, 2018, 7:11am
Is "n_18_mm" a mismatch model? If you look in the model files, can you determine if it is a subckt or model card? If you use regular (not mismatch) models, does the simulation work?
(You probably should not post the actual model files, since this is UMC's IP and it would likely violate an NDA.)
