Feb 7th, 2026, 8:05am
pss does not converge (Read 12193 times)
sanazadib
Oct 30th, 2016, 8:57am
Hi everyone
I design clock generator that create four non overlap clock at 1 GHZ,in fact I have four non overlap clock which each one has frequency of 1Ghz
I can do transient analysis and it gives me four non overlap clock at 1Ghz,however when I do PSS analysis I got converge problem,it said it does not converge .
I change tstab and some parameter but still give me this error
anybody have any idea?
Thanks in advance
Re: pss does not converge
Reply #1 - Nov 1st, 2016, 8:09am
I think I remember reading that PSS can have convergence difficulties if any of the clocks is transitioning at the end of the period.
sanazadib
Reply #2 - Nov 1st, 2016, 12:32pm
Actually I did transient analysis and I create layout for my clock generator  ,and this is my RLC extraction from clock generator
Reply #3 - Nov 1st, 2016, 4:32pm
Autonomous or driven?
sanazadib
Reply #4 - Nov 2nd, 2016, 7:23am
Actually I inject 4GhZ Clock generator and it gives me four non overlap clock at 1Ghz,structure of clock is consist of flipflop(transmission gate and inverter) ,inverter  .nor gate and so on
I try different tstab,different tolerance option ,still did no work
result that I show above is transient result where I did RLC extraction
sanazadib
Reply #5 - Nov 2nd, 2016, 3:22pm
Periodic Steady-State Analysis `pss': fund = 4 GHz
Trying `homotopy = gmin' for initial conditions.
Notice from spectre during IC analysis, during periodic steady state analysis `pss'.
   GminDC = 1 pS is large enough to noticeably affect the DC solution.
       dV(I0.I171|I1|T3:int_d) = -93.7384 mV
       Use the `gmin_check' option to eliminate or expand this report.
   Bad pivoting is found during DC analysis. Option dc_pivot_check=yes is recommended for possible improvement of convergence.
DC simulation time: CPU = 899.863 ms, elapsed = 900.905 ms.
`pss': time = (0 s -> 20.25 ns)
Output and IC/nodeset summary:
                save   1357    (current)
                save   4238    (voltage)
Important parameter values in tstab integration:
   start = 0 s
   outputstart = 0 s
   stop = 20.25 ns
   period = 250 ps
   maxperiods = 20
   step = 20.25 ps
   maxstep = 10 ps
   ic = all
   useprevic = no
   skipdc = no
   reltol = 1e-03
   abstol(V) = 1 uV
   abstol(I) = 1 pA
   temp = 27 C
   tnom = 27 C
   tempeffects = all
   method = gear2
   lteratio = 3.5
   relref = sigglobal
   cmin = 0 F
   gmin = 1 pS
   pss: time = 486.4 ps     (2.4 %), step = 3.854 ps      (19 m%)
   pss: time = 506.7 ps     (2.5 %), step = 488.8 fs    (2.41 m%)
   pss: time = 907.1 ps    (4.48 %), step = 564.8 fs    (2.79 m%)
   pss: time = 1.373 ns    (6.78 %), step = 2.734 ps    (13.5 m%)
   pss: time = 1.519 ns     (7.5 %), step = 1.12 ps     (5.53 m%)
   pss: time = 2 ns        (9.88 %), step = 1.692 ps    (8.36 m%)
   pss: time = 2.463 ns    (12.2 %), step = 2.118 ps    (10.5 m%)
   pss: time = 2.531 ns    (12.5 %), step = 675.8 fs    (3.34 m%)
   pss: time = 3.076 ns    (15.2 %), step = 2.231 ps      (11 m%)
   pss: time = 3.545 ns    (17.5 %), step = 1.011 ps    (4.99 m%)
   pss: time = 4.137 ns    (20.4 %), step = 779.8 fs    (3.85 m%)
   pss: time = 4.557 ns    (22.5 %), step = 1.441 ps    (7.12 m%)
   pss: time = 5.016 ns    (24.8 %), step = 946.5 fs    (4.67 m%)
   pss: time = 5.411 ns    (26.7 %), step = 563.4 fs    (2.78 m%)
   pss: time = 5.569 ns    (27.5 %), step = 2.164 ps    (10.7 m%)
   pss: time = 6.006 ns    (29.7 %), step = 733.7 fs    (3.62 m%)
   pss: time = 6.427 ns    (31.7 %), step = 1.409 ps    (6.96 m%)
   pss: time = 6.581 ns    (32.5 %), step = 2.338 ps    (11.5 m%)
   pss: time = 7.018 ns    (34.7 %), step = 684.8 fs    (3.38 m%)
   pss: time = 7.414 ns    (36.6 %), step = 1.088 ps    (5.37 m%)
   pss: time = 7.595 ns    (37.5 %), step = 2.591 ps    (12.8 m%)
   pss: time = 8.021 ns    (39.6 %), step = 1.541 ps    (7.61 m%)
   pss: time = 8.499 ns      (42 %), step = 1.46 ps     (7.21 m%)
   pss: time = 8.606 ns    (42.5 %), step = 1.191 ps    (5.88 m%)
   pss: time = 9.085 ns    (44.9 %), step = 1.316 ps     (6.5 m%)
   pss: time = 9.544 ns    (47.1 %), step = 1.217 ps    (6.01 m%)
   pss: time = 9.621 ns    (47.5 %), step = 2.987 ps    (14.7 m%)
   pss: time = 10.01 ns    (49.4 %), step = 722.2 fs    (3.57 m%)
   pss: time = 10.4 ns     (51.4 %), step = 432.4 fs    (2.14 m%)
   pss: time = 10.63 ns    (52.5 %), step = 628.1 fs     (3.1 m%)
   pss: time = 11.16 ns    (55.1 %), step = 601 fs      (2.97 m%)
   pss: time = 11.64 ns    (57.5 %), step = 859.6 fs    (4.24 m%)
   pss: time = 12.22 ns    (60.3 %), step = 3.403 ps    (16.8 m%)
   pss: time = 12.66 ns    (62.5 %), step = 700.7 fs    (3.46 m%)
   pss: time = 13.18 ns    (65.1 %), step = 2.268 ps    (11.2 m%)
   pss: time = 13.67 ns    (67.5 %), step = 1.191 ps    (5.88 m%)
   pss: time = 14.18 ns      (70 %), step = 1.814 ps    (8.96 m%)
   pss: time = 14.68 ns    (72.5 %), step = 2.16 ps     (10.7 m%)
   pss: time = 15.3 ns     (75.5 %), step = 418.4 fs    (2.07 m%)
   pss: time = 15.7 ns     (77.5 %), step = 3.053 ps    (15.1 m%)
   pss: time = 16.3 ns     (80.5 %), step = 865 fs      (4.27 m%)
   pss: time = 16.71 ns    (82.5 %), step = 3.65 ps       (18 m%)
   pss: time = 17.3 ns     (85.5 %), step = 974.5 fs    (4.81 m%)
   pss: time = 17.72 ns    (87.5 %), step = 1.454 ps    (7.18 m%)
   pss: time = 18.35 ns    (90.6 %), step = 897.2 fs    (4.43 m%)
   pss: time = 18.73 ns    (92.5 %), step = 3.033 ps      (15 m%)
   pss: time = 19.35 ns    (95.6 %), step = 908.3 fs    (4.49 m%)
   pss: time = 19.74 ns    (97.5 %), step = 2.216 ps    (10.9 m%)
Total time required for tstab analysis `pss': CPU = 394.933 s (6m  34.9s), elapsed = 399.07 s (6m  39.1s).
Time accumulated: CPU = 394.934 s (6m  34.9s), elapsed = 399.07 s (6m  39.1s).
Peak resident memory used = 121 Mbytes.
Conv norm = 12.8e+03, max dV(I0.I222|I217|I187|T3:int_d) = 1.52032 V, took 393.25 s.
Important parameter values in pss iteration:
   start = 20 ns
   outputstart = 0 s
   stop = 20.25 ns
   period = 250 ps
   maxperiods = 20
   steadyratio = 10e-03
   step = 20.25 ps
   maxstep = 1.25 ps
   ic = all
   useprevic = no
   skipdc = no
   reltol = 100e-06
   abstol(V) = 1 uV
   abstol(I) = 1 pA
   temp = 27 C
   tnom = 27 C
   tempeffects = all
   errpreset = conservative
   method = gear2
   lteratio = 10
   relref = alllocal
   cmin = 0 F
   gmin = 1 pS
`pss': time = (20 ns -> 20.25 ns)
   pss: time = 20.01 ns     (2.6 %), step = 253
sanazadib
Reply #6 - Nov 2nd, 2016, 3:24pm
Warning from spectre at time = 20.0002 ns during periodic steady state analysis `pss'.
   WARNING (SPECTRE-16266): Error requirements were not satisfied because of convergence difficulties.
   pss: time = 20 ns      (97.9 m%), step = 10.83 fs    (4.33 m%)
Warning from spectre at time = 20.0003 ns during periodic steady state analysis `pss'.
       Further occurrences of this warning will be suppressed.
   pss: time = 20 ns       (133 m%), step = 59.28 fs    (23.7 m%)
   pss: time = 20 ns       (151 m%), step = 30.14 fs    (12.1 m%)
   pss: time = 20 ns       (187 m%), step = 50.2 fs     (20.1 m%)
   pss: time = 20 ns       (227 m%), step = 51.64 fs    (20.7 m%)
Jacobian was reordered during integration. Don't use swap file in PSS analysis
   pss: time = 20 ns       (256 m%), step = 10.17 fs    (4.07 m%)
   pss: time = 20 ns       (466 m%), step = 4.955 fs    (1.98 m%)
   pss: time = 20 ns       (849 m%), step = 28.64 fs    (11.5 m%)
   pss: time = 20 ns       (1.44 %), step = 49.64 fs    (19.9 m%)
   pss: time = 20 ns       (1.93 %), step = 10.16 fs    (4.06 m%)
   pss: time = 20.01 ns    (2.27 %), step = 9.225 fs    (3.69 m%)
   pss: time = 20.01 ns    (2.47 %), step = 3.324 fs    (1.33 m%)
   pss: time = 20.01 ns     (2.5 %), step = 16.59 fs    (6.64 m%)
   pss: time = 20.01 ns    (2.79 %), step = 15.14 fs    (6.06 m%)
   pss: time = 20.01 ns    (3.25 %), step = 13.1 fs     (5.24 m%)
   pss: time = 20.01 ns    (3.55 %), step = 52.38 fs      (21 m%)
   pss: time = 20.01 ns    (4.02 %), step = 49.2 fs     (19.7 m%)
   pss: time = 20.01 ns    (4.19 %), step = 2.91 fs     (1.16 m%)
   pss: time = 20.01 ns    (4.77 %), step = 43.44 fs    (17.4 m%)
   pss: time = 20.01 ns    (5.27 %), step = 21.82 fs    (8.73 m%)
   pss: time = 20.01 ns    (5.65 %), step = 31.5 fs     (12.6 m%)
   pss: time = 20.02 ns    (6.08 %), step = 33.41 fs    (13.4 m%)
   pss: time = 20.02 ns    (6.66 %), step = 6.118 fs    (2.45 m%)
   pss: time = 20.02 ns    (7.04 %), step = 12.45 fs    (4.98 m%)
   pss: time = 20.02 ns     (7.5 %), step = 40.55 fs    (16.2 m%)
   pss: time = 20.02 ns    (8.18 %), step = 21.31 fs    (8.52 m%)
   pss: time = 20.02 ns    (8.56 %), step = 7.893 fs    (3.16 m%)
   pss: time = 20.02 ns    (9.26 %), step = 25.27 fs    (10.1 m%)
   pss: time = 20.03 ns    (10.3 %), step = 28.73 fs    (11.5 m%)
   pss: time = 20.03 ns      (11 %), step = 12.16 fs    (4.86 m%)
   pss: time = 20.03 ns    (11.5 %), step = 36.91 fs    (14.8 m%)
   pss: time = 20.03 ns    (12.3 %), step = 40.89 fs    (16.4 m%)
   pss: time = 20.03 ns    (12.5 %), step = 90.72 fs    (36.3 m%)
   pss: time = 20.03 ns    (12.9 %), step = 91.41 fs    (36.6 m%)
   pss: time = 20.03 ns    (13.5 %), step = 50.25 fs    (20.1 m%)
   pss: time = 20.03 ns    (13.9 %), step = 96.42 fs    (38.6 m%)
   pss: time = 20.04 ns    (14.3 %), step = 26.18 fs    (10.5 m%)
   pss: time = 20.04 ns    (14.5 %), step = 30.52 fs    (12.2 m%)
   pss: time = 20.04 ns    (14.7 %), step = 30.52 fs    (12.2 m%)
   pss: time = 20.04 ns      (15 %), step = 32.17 fs    (12.9 m%)
   pss: time = 20.04 ns    (15.2 %), step = 34.06 fs    (13.6 m%)
   pss: time = 20.04 ns    (15.6 %), step = 35.63 fs    (14.3 m%)
   pss: time = 20.04 ns    (15.8 %), step = 35.63 fs    (14.3 m%)
   pss: time = 20.04 ns      (16 %), step = 33.69 fs    (13.5 m%)
   pss: time = 20.04 ns    (16.3 %), step = 32.39 fs      (13 m%)
   pss: time = 20.04 ns    (16.5 %), step = 32.39 fs      (13 m%)
   pss: time = 20.04 ns    (16.9 %), step = 34.03 fs    (13.6 m%)
   pss: time = 20.04 ns    (17.1 %), step = 34.45 fs    (13.8 m%)
   pss: time = 20.04 ns    (17.5 %), step = 33.13 fs    (13.3 m%)
   pss: time = 20.04 ns    (17.5 %), step = 37.25 fs    (14.9 m%)
   pss: time = 20.04 ns    (17.9 %), step = 47.08 fs    (18.8 m%)
   pss: time = 20.05 ns    (18.2 %), step = 86.16 fs    (34.5 m%)
   pss: time = 20.05 ns    (18.5 %), step = 92.15 fs    (36.9 m%)
   pss: time = 20.05 ns    (18.7 %), step = 37.03 fs    (14.8 m%)
   pss: time = 20.05 ns      (19 %), step = 24.88 fs    (9.95 m%)
   pss: time = 20.05 ns    (19.2 %), step = 30.69 fs    (12.3 m%)
   pss: time = 20.05 ns    (19.5 %), step = 61.37 fs    (24.5 m%)
   pss: time = 20.05 ns    (19.6 %), step = 29.01 fs    (11.6 m%)
   pss: time = 20.05 ns    (19.9 %), step = 30.69 fs    (12.3 m%)
   pss: time = 20.05 ns    (20.3 %), step = 42.73 fs    (17.1 m%)
   pss: time = 20.05 ns    (20.5 %), step = 35.89 fs    (14.4 m%)
   pss: time = 20.05 ns    (20.8 %), step = 22.84 fs    (9.13 m%)
   pss: time = 20.05 ns    (21.1 %), step = 35.84 fs    (14.3 m%)
   pss: time = 20.05 ns    (21.3 %), step = 71.68 fs    (28.7 m%)
   pss:
deba
Reply #7 - Nov 4th, 2016, 5:15pm
I think the circuit which you are trying is a 25% duty cycle generator for mixers. Do you have slow settling nodes in your circuit? Like some biasing ? Is PSS not converging for schematic or extraction?
Reply #8 - Nov 5th, 2016, 10:35pm
If the inputs are periodic in 1GHz, why are you specifying 4GHz as the fundamental frequency?
sanazadib
Reply #9 - Nov 8th, 2016, 8:46am
deba wrote on Nov 4th, 2016, 5:15pm:
Yes,duty cycle is 25%, No I do not have any biasing except vdd
Pss does not converge for schematic  and also extraction
sanazadib
Reply #10 - Nov 8th, 2016, 8:50am
[quote author=kundert link=1477843044/0#8 date=1478410502] Quote:
input is 4Ghz clcok and output is four nonoverlap clcok at 1Ghz
I even  change input frequncy  to 1Ghz ,did not converge again
Periodic Steady-State Analysis `pss': fund = 1 GHz
DC simulation time: CPU = 834.874 ms, elapsed = 833.564 ms.
`pss': time = (0 s -> 21 ns)
   start = 0 s
   outputstart = 0 s
   stop = 21 ns
   period = 1 ns
   maxperiods = 20
   step = 21 ps
   maxstep = 40 ps
   ic = all
   useprevic = no
   skipdc = no
   reltol = 1e-03
   abstol(V) = 1 uV
   abstol(I) = 1 pA
   temp = 27 C
   tnom = 27 C
   tempeffects = all
   method = gear2
   lteratio = 3.5
   relref = sigglobal
   cmin = 0 F
   gmin = 1 pS
   pss: time = 525 ps       (2.5 %), step = 483.5 fs     (2.3 m%)
   pss: time = 1.287 ns    (6.13 %), step = 863.3 fs    (4.11 m%)
   pss: time = 1.578 ns    (7.51 %), step = 2.744 ps    (13.1 m%)
   pss: time = 2.44 ns     (11.6 %), step = 1.996 ps     (9.5 m%)
   pss: time = 2.625 ns    (12.5 %), step = 1.971 ps    (9.39 m%)
   pss: time = 3.492 ns    (16.6 %), step = 2.259 ps    (10.8 m%)
   pss: time = 3.676 ns    (17.5 %), step = 1.363 ps    (6.49 m%)
   pss: time = 4.543 ns    (21.6 %), step = 1.086 ps    (5.17 m%)
   pss: time = 4.726 ns    (22.5 %), step = 2.499 ps    (11.9 m%)
   pss: time = 5.598 ns    (26.7 %), step = 2.286 ps    (10.9 m%)
   pss: time = 5.775 ns    (27.5 %), step = 607.5 fs    (2.89 m%)
   pss: time = 6.638 ns    (31.6 %), step = 999.4 fs    (4.76 m%)
   pss: time = 6.826 ns    (32.5 %), step = 1.418 ps    (6.75 m%)
   pss: time = 7.632 ns    (36.3 %), step = 630.2 fs       (3 m%)
   pss: time = 7.875 ns    (37.5 %), step = 1.099 ps    (5.23 m%)
   pss: time = 8.646 ns    (41.2 %), step = 471.5 fs    (2.25 m%)
   pss: time = 8.925 ns    (42.5 %), step = 1.071 ps     (5.1 m%)
   pss: time = 9.742 ns    (46.4 %), step = 2.252 ps    (10.7 m%)
   pss: time = 9.976 ns    (47.5 %), step = 2.458 ps    (11.7 m%)
   pss: time = 10.86 ns    (51.7 %), step = 2.665 ps    (12.7 m%)
   pss: time = 11.03 ns    (52.5 %), step = 449 fs      (2.14 m%)
   pss: time = 11.91 ns    (56.7 %), step = 733.5 fs    (3.49 m%)
   pss: time = 12.08 ns    (57.5 %), step = 2.222 ps    (10.6 m%)
   pss: time = 12.99 ns    (61.8 %), step = 1.774 ps    (8.45 m%)
   pss: time = 13.13 ns    (62.5 %), step = 2.464 ps    (11.7 m%)
   pss: time = 14.01 ns    (66.7 %), step = 631.9 fs    (3.01 m%)
   pss: time = 14.18 ns    (67.5 %), step = 1.58 ps     (7.53 m%)
   pss: time = 15.06 ns    (71.7 %), step = 1.931 ps    (9.19 m%)
   pss: time = 15.23 ns    (72.5 %), step = 2.676 ps    (12.7 m%)
   pss: time = 16.12 ns    (76.8 %), step = 1.729 ps    (8.23 m%)
   pss: time = 16.28 ns    (77.5 %), step = 286.2 fs    (1.36 m%)
   pss: time = 17.15 ns    (81.7 %), step = 868.3 fs    (4.13 m%)
   pss: time = 17.33 ns    (82.5 %), step = 1.19 ps     (5.67 m%)
   pss: time = 18.19 ns    (86.6 %), step = 2.236 ps    (10.6 m%)
   pss: time = 18.38 ns    (87.5 %), step = 2.002 ps    (9.53 m%)
   pss: time = 19.18 ns    (91.3 %), step = 2.22 ps     (10.6 m%)
   pss: time = 19.43 ns    (92.5 %), step = 1.16 ps     (5.53 m%)
   pss: time = 20.26 ns    (96.5 %), step = 656.6 fs    (3.13 m%)
   pss: time = 20.48 ns    (97.5 %), step = 2.918 ps    (13.9 m%)
Total time required for tstab analysis `pss': CPU = 249.32 s (4m  9.3s), elapsed = 250.305 s (4m  10.3s).
Time accumulated: CPU = 249.32 s (4m  9.3s), elapsed = 250.305 s (4m  10.3s).
Peak resident memory used = 111 Mbytes.
Conv norm = 12.8e+03, max dV(I0.I212|I0|T2_1__rcx:int_d) = 1.51496 V, took 247.78 s.
   start = 20 ns
   outputstart = 0 s
   stop = 21 ns
   period = 1 ns
   maxperiods = 20
   step = 21 ps
   maxstep = 5 ps
   ic = all
   useprevic = no
   skipdc = no
   reltol = 100e-06
   abstol(V) = 1 uV
   abstol(I) = 1 pA
   temp = 27 C
   tnom = 27 C
   tempeffects = all
   method = gear2
   lteratio = 10
   relref = alllocal
   cmin = 0 F
   gmin = 1 pS
`pss': time = (20 ns -> 21 ns)
   pss: time = 20.03 ns    (2.51 %), step = 91.17 fs    (9.12 m%)
   pss: time = 20.08 ns     (7.5 %), step = 398.3 fs    (39.8 m%)
   pss: time = 20.13 ns    (12.5 %), step = 111.1 fs    (11.1 m%)
   pss: time = 20.18 ns    (17.5 %), step = 625.7 fs    (62.6 m%)
   pss: time = 20.23 ns    (22.5 %), step = 422.5 fs    (42.3 m%)
   pss: time = 20.28 ns    (27.5 %), step = 91.64 fs    (9.16 m%)
   pss: time = 20.33 ns    (32.5 %), step = 678 fs      (67.8 m%)
sanazadib
Reply #11 - Nov 8th, 2016, 8:52am
   pss: time = 20.38 ns    (37.5 %), step = 585.3 fs    (58.5 m%)
   pss: time = 20.43 ns    (42.5 %), step = 709.4 fs    (70.9 m%)
   pss: time = 20.48 ns    (47.5 %), step = 1.273 ps     (127 m%)
   pss: time = 20.53 ns    (52.5 %), step = 221.2 fs    (22.1 m%)
   pss: time = 20.58 ns    (57.5 %), step = 451.2 fs    (45.1 m%)
   pss: time = 20.63 ns    (62.5 %), step = 211.3 fs    (21.1 m%)
   pss: time = 20.68 ns    (67.5 %), step = 772.1 fs    (77.2 m%)
   pss: time = 20.73 ns    (72.6 %), step = 1.436 ps     (144 m%)
   pss: time = 20.78 ns    (77.5 %), step = 98.64 fs    (9.86 m%)
   pss: time = 20.83 ns    (82.5 %), step = 529 fs      (52.9 m%)
   pss: time = 20.87 ns    (87.5 %), step = 987.9 fs    (98.8 m%)
   pss: time = 20.93 ns    (92.6 %), step = 753.8 fs    (75.4 m%)
   pss: time = 20.98 ns    (97.6 %), step = 1.525 ps     (152 m%)
Conv norm = 2.94e+03, max dV(I0.I212|I0|T1:int_d) = -45.9961 mV, took 68.62 s.
   pss: time = 20.03 ns    (2.51 %), step = 88.82 fs    (8.88 m%)
   pss: time = 20.08 ns    (7.54 %), step = 1.08 ps      (108 m%)
   pss: time = 20.13 ns    (12.5 %), step = 126.6 fs    (12.7 m%)
   pss: time = 20.18 ns    (17.5 %), step = 629.2 fs    (62.9 m%)
   pss: time = 20.23 ns    (22.5 %), step = 818.5 fs    (81.9 m%)
   pss: time = 20.28 ns    (27.5 %), step = 74.51 fs    (7.45 m%)
   pss: time = 20.33 ns    (32.5 %), step = 392.7 fs    (39.3 m%)
   pss: time = 20.38 ns    (37.5 %), step = 937.5 fs    (93.8 m%)
   pss: time = 20.43 ns    (42.5 %), step = 774.3 fs    (77.4 m%)
   pss: time = 20.48 ns    (47.5 %), step = 1.262 ps     (126 m%)
   pss: time = 20.53 ns    (52.5 %), step = 291.3 fs    (29.1 m%)
   pss: time = 20.58 ns    (57.5 %), step = 742 fs      (74.2 m%)
   pss: time = 20.63 ns    (62.5 %), step = 187.4 fs    (18.7 m%)
   pss: time = 20.68 ns    (67.5 %), step = 758.3 fs    (75.8 m%)
   pss: time = 20.73 ns    (72.5 %), step = 1.199 ps     (120 m%)
   pss: time = 20.78 ns    (77.5 %), step = 97.55 fs    (9.76 m%)
   pss: time = 20.83 ns    (82.5 %), step = 435.3 fs    (43.5 m%)
   pss: time = 20.87 ns    (87.5 %), step = 979.8 fs      (98 m%)
   pss: time = 20.93 ns    (92.6 %), step = 758.6 fs    (75.9 m%)
   pss: time = 20.98 ns    (97.6 %), step = 949.6 fs      (95 m%)
Conv norm = 167, max dV(I0.I209|I184|T5:int_d) = -2.43831 mV, took 64.06 s.
   pss: time = 20.03 ns    (2.51 %), step = 90.86 fs    (9.09 m%)
   pss: time = 20.08 ns    (7.57 %), step = 842 fs      (84.2 m%)
   pss: time = 20.13 ns    (12.5 %), step = 114.1 fs    (11.4 m%)
   pss: time = 20.18 ns    (17.5 %), step = 696.7 fs    (69.7 m%)
   pss: time = 20.23 ns    (22.5 %), step = 808.4 fs    (80.8 m%)
   pss: time = 20.28 ns    (27.5 %), step = 89.89 fs    (8.99 m%)
   pss: time = 20.33 ns    (32.5 %), step = 781.5 fs    (78.2 m%)
   pss: time = 20.38 ns    (37.5 %), step = 848.3 fs    (84.8 m%)
   pss: time = 20.43 ns    (42.5 %), step = 759.5 fs    (75.9 m%)
   pss: time = 20.48 ns    (47.5 %), step = 1.328 ps     (133 m%)
   pss: time = 20.53 ns    (52.5 %), step = 282.4 fs    (28.2 m%)
   pss: time = 20.58 ns    (57.5 %), step = 462 fs      (46.2 m%)
   pss: time = 20.63 ns    (62.5 %), step = 232.5 fs    (23.3 m%)
   pss: time = 20.68 ns    (67.5 %), step = 768.7 fs    (76.9 m%)
   pss: time = 20.73 ns    (72.5 %), step = 1.384 ps     (138 m%)
   pss: time = 20.78 ns    (77.5 %), step = 90.51 fs    (9.05 m%)
   pss: time = 20.83 ns    (82.5 %), step = 583.7 fs    (58.4 m%)
   pss: time = 20.87 ns    (87.5 %), step = 716.7 fs    (71.7 m%)
   pss: time = 20.93 ns    (92.6 %), step = 759.1 fs    (75.9 m%)
   pss: time = 20.98 ns    (97.6 %), step = 1.966 ps     (197 m%)
Conv norm = 94.4, max dV(I0.I212|I0|T3:int_g) = -1.43786 mV, took 62.84 s.
   pss: time = 20.13 ns    (12.5 %), step = 120.7 fs    (12.1 m%)
   pss: time = 20.18 ns    (17.5 %), step = 442.2 fs    (44.2 m%)
   pss: time = 20.23 ns    (22.5 %), step = 820.8 fs    (82.1 m%)
   pss: time = 20.28 ns    (27.5 %), step = 79.16 fs    (7.92 m%)
   pss: time = 20.33 ns    (32.5 %), step = 691 fs      (69.1 m%)
   pss: time = 20.38 ns    (37.5 %), step = 987.3 fs    (98.7 m%)
   pss: time = 20.43 ns    (42.5 %), step = 804.3 fs    (80.4 m%)
   pss: time = 20.48 ns    (47.6 %), step = 1.368 ps     (137 m%)
   pss: time = 20.53 ns    (52.5 %), step = 207 fs      (20.7 m%)
   pss: time = 20.58 ns    (57.5 %), step = 968.1 fs    (96.8 m%)
   pss: time = 20.63 ns    (62.5 %), step = 199.8 fs      (20 m%)
   pss: time = 20.68 ns    (67.6 %), step = 775.1 fs    (77.5 m%)
deba
Reply #12 - Nov 8th, 2016, 5:50pm
Your input is fin and output is at fin/4. The PSS fundamental period should be defined as fin/4. For 4 GHz, you should use 1 GHz. Similarly for 1 GHz, beat is 250 MHz.
