Feb 7th, 2026, 8:49am
writiing verilog -a time data to file (Read 2292 times)
openloop
Feb 27th, 2017, 2:13pm
I need to find a command for Verilog -a that will let me write the time that a crossing event occurs.  $realtime seems close, but how do I get this into a file for processing later?
Re: writiing verilog -a time data to file
Reply #1 - Feb 28th, 2017, 12:21pm
openloop wrote on Feb 27th, 2017, 2:13pm:
You should use $abstime instead of $realtime, which is not officially supported in the analog context.
You should be able to use $fstrobe or $fwrite to write to a file.
Reply #2 - Feb 28th, 2017, 4:41pm
With a crossing event, you should also use last_crossing along with cross to get the best accuracy. See time interval measurement for a template.
openloop
Reply #3 - Mar 1st, 2017, 6:43am
Thanks all for helping.
