Oct 10th, 2026, 6:34pm
creating compile time define switch in .scs file (Read 7953 times)
AMS_ei
Apr 17th, 2017, 10:50pm
I am planning to have a switch in order to have control in specific netlist or in .scs file.
Is there any way to apply a compile time define switch in .scs file? (something like `ifdef in system verilog/verilog ams)?
Thank you.
Kind regards
Re: creating compile time define switch in .scs file
Reply #1 - Apr 21st, 2017, 12:32pm
Yes. Use the cpp (C pre-processor) directives #ifdef, #ifndef etc, and then run "spectre -Dvar" or "spectre -Dvar=val" to define them on the command line. You can also just run "spectre -E" to invoke with the C preprocessor first, which happens if you pass -D too.  More on cpp can be found in "man cpp".
Andrew
AMS_ei
Reply #2 - Apr 25th, 2017, 4:46am
Hi Andrew,
Thank you for your valuable inputs.
Could you please tell me how can I pass it through "irun"?
Thank you.
Kind regards.
Reply #3 - May 28th, 2017, 1:35pm
Add this to the irun command line:
-spectre_args '-E -Dvar'
or:
-spectre_args '-E -Dvar=val'
Note that you have to pass the -E, because otherwise I think the -Dvar just gets passed to irun as a macro definition for the Verilog `ifdef etc.
Andrew
AMS_ei
Reply #4 - May 30th, 2017, 3:45am
Hi Andrew,
This seems to be not working if I insert amsd{} block in the amscf.scs file.
Is there any workaround for that?
Thank you.
Kind regards.
Reply #5 - Jun 2nd, 2017, 11:37pm
Something seems to be odd if you use #ifdef around or within the amsd block. My quick experiments seem to show that #ifndef works, but #ifdef doesn't. Odd...
I suggest that you contact Cadence Customer Support at http://support.cadence.com
Andrew
