Nov 10th, 2026, 7:08pm
Verilog A models, Convergence (Read 3812 times)
balshoy
USA
May 06th, 2017, 6:38am
Hi
I am developing Verilog A model for an emerging device. That VerilogA model will be instantiated within an .scs file to run spectre simulations. I have a couple of questions regarding that:
1) As far as I know, spice-like simulators (LTspice, spectre, eldo..etc) have some hard coded models for some elements. Numerical solutions for circuits with such elements are well documented and the methods are known. But, when I use a verilogA model to describe a device, does spectre translate it first to a network of such elements and then solves (something like synthesis in digital) or it operates on the verilogA equations right away?
2)do the algorithms that apply to spice models (eg. NR) also apply to verilogA models?
Re: Verilog A models, Convergence
Reply #1 - May 6th, 2017, 3:36pm
1. The Verilog-A equations are evaluated directly.
2. Yes. The equations from all components, whether built-in or described with Verilog-A, are combined and solved simultaneously using the conventional SPICE algorithms (conversion to difference equations, Newton Raphson, sparse matrix techniques).
« Last Edit: May 7th, 2017, 1:41pm by Ken Kundert »
balshoy
USA
Reply #2 - May 7th, 2017, 4:44am
Thanks Ken.
