Feb 11th, 2026, 10:26pm
For MOS Cap, is the a depletion region in MOS when VFB < VGB < 0? (Read 6346 times)
mpig09
May 25th, 2017, 5:47pm
Hi all:
Many books explain the MOS Cap value is Cox(oxide cap) serial Cdep(depletion cap) when VFB < VGB < VTH,
I have a questions: is there a depletion region in MOS when VFB < VGB < 0?
VFB : Flat band voltage
If Yes, could you help me to understand it.
Thank.
mpig
Maks
San Jose
Re: For MOS Cap, is the a depletion region in MOS when VFB < VGB < 0?
Reply #1 - May 27th, 2017, 1:58pm
There is always depletion region when Vg > VFB.
At Vg> Vt though, the depletion regions is "screened" (or shielded) by the inversion layer (a thin layer of electrons in the channel, at the Si/oxide interface, supplied from N+ source/drain regions).
If you want to understand what all these terms mean - depletion, deep depletion, accumulation, inversion - you can read any textbook on semiconductor device physics (for example, S.Sze book "Physics of semiconductor devices").
Max
mpig09
Reply #2 - Jun 5th, 2017, 2:49am
Hi Max:
I have solved the problem.
Smiley
mpig
