Mar 29th, 2024, 4:10am
Regarding issue with absdelta (Read 3495 times)
AMS_ei
May 28th, 2017, 5:37am
I am trying to achieve electrical to real conversion using "absdelta".
Here is my code:
//code starts here/////////
module elec2real(signal);
 input signal;
 electrical signal;
 real sig_vol;
 initial begin
   sig_vol = 0;
 always @(absdelta(V(signal), 0.01)) begin
   sig_vol = V(signal);
//Code ends here///////////////
The issue is that when V(signal) is 0V, sig_vol is driven to -4.44089e-16 as shown in the attached file.
Could anyone please explain me how can I resolve this issue?
Thank you.
Kind regards.
AMS_ei
Re: Regarding issue with absdelta
Reply #1 - May 28th, 2017, 6:21am
The waves of V(signal) and sig_vol is attached
Reply #2 - May 28th, 2017, 4:30pm
What issue? Are you concerned with a difference of less than a fV?
AMS_ei
Reply #3 - May 29th, 2017, 8:48pm
Hi Ken,
Thank you for your interest
I am bit concerned about its -ve value.
I was expecting a +ve value (may be in the order of fV) but, it should be +ve.
Is it possible to obtain that?
Thank you.
Kind regards.
Reply #4 - May 30th, 2017, 12:08am
Simulators cannot provide the accuracy you are looking for. There is always a small amount of uncertainty in the result.
