Sep 15th, 2026, 4:37pm
Netlist generation from config view (Read 4184 times)
Gp
Jun 15th, 2017, 5:02am
Hi All,
I am using the cadence virtuoso tool. I created the config view from the schematic. For Verilog-AMS netlist generate, I use the following command line:
runams -lib lib_name -cell cell_name -view config -netlist -rundir top_dir
Now my question is, How to generate the .amsbind.scs file with netlist?which contain connect module (amscf.scs) .
Is there a missing option in command line?
Thanks.
Re: Netlist generation from config view
Reply #1 - Jul 25th, 2017, 8:17am
runams will do this provided that the netlist assembly succeeded - it's in the rundir/netlist.
To generate an analog control file, you'd have to pass -state so that it has an ADE state to specify the analysis set up and so on. Otherwise you can write your own and pass -analogcontrol to the runams command line.
