John Rankin
I would like to use the ideal SH verilogA block to combine the outputs of a time interleaved sampler. I tried doing this by placing 2 of them in a netlist and varying the sample times, but I get an error from spectre :
FATAL: The following branches form a loop of rigid branches (shorts) when added to the circuit: I32:Pout_Nout_flow (from net012 to 0)
Is there a version of this model somewhere that allows me to sample multiple nodes and combine them into one output? If not, how would you guys recommend modifying the model?
Thanks, John
