Apr 19th, 2024, 11:25pm
Ideal SH time interleaving (Read 1579 times)
John Rankin
Aug 02nd, 2017, 5:29am
I would like to use the ideal SH verilogA block to combine the outputs of a time interleaved sampler. I tried doing this by placing 2 of them in a netlist and varying the sample times, but I get an error from spectre :
FATAL: The following branches form a loop of rigid branches (shorts) when added to the circuit:
       I32:Pout_Nout_flow (from net012 to 0)
Is there a version of this model somewhere that  allows me to sample multiple nodes and combine them into one output? If not, how would you guys recommend modifying the model?
John
John Rankin
Re: Ideal SH time interleaving
Reply #1 - Aug 2nd, 2017, 5:31am
Just FYI here is an image of the schematic if that helps understand what I am trying to achieve.
