baohulu
china
in the plane vertical to the inductor ring , the magnetic line can be described as "in" and "out" two direction , though the magnetic line is continuous all the time.
if the width of the inductor is opposite, the inside inductor ring width is wider than the outside ring width, the inductor can also hold the same area, or say, the same outer diameter, do you think the two type inductors have the same performance ?
