Apr 25th, 2024, 12:11am
Class E amplifier (Read 1827 times)
atifnawaz08
Class E amplifier
Sep 12th, 2017, 6:28am
Hello, I am trying to design a class E amplifier for inductive data coupling. I designed it for 150u Watts of Output power. I am using 130nm UMC process. The waveform for voltage through transister has many  harmonics. I want to get a nice class E waveform. Can anyone guide me where may be the Problem and what can I do to deal with it? Attached is a screenshot of the waveform. M1/D and net 3 are the voltage and current through the transister while R0/plus is the load current.
View Profile atifnawaz08   IP Logged
Horror Vacui
Dresden, Germany
Re: Class E amplifier
Reply #1 - Oct 22nd, 2017, 12:15pm
Though I had only cursory readings about Class-E amps, but the series LC at the output should filter out the unintended harmonics.
