Aug 31st, 2024, 4:09pm
Assertions inside Connect Modules (Read 188 times)
sgh2050
Sep 18th, 2017, 8:03am
Hi All,
I am new to AMS verification. I have following question.
Please let me know if I can place assertions inside connect module for E2L. The purpose is to check that Signals coming from analog to digital are at 1.2 V level. This is to check that there are Level shifters in analog so that 3.3v is correctly converted to 1.2V before going to digital
We use Cadence. How can i tell cadence irun to pick a  a custom E2L connect module
Best Regards
nischaybm
Re: Assertions inside Connect Modules
Reply #1 - Nov 30th, 2017, 1:12am
Hi sgh2050,
I am not sure if you can add assertions, that may need you to have a clk signal.
default connect module doesn't complain if the signal Voltage is higher than expected.
you can right your own connect modules for this purpose, you can include them like them in ADE,
ADE--> SETUP --> connect Rules
