Apr 19th, 2024, 10:50am
Pages: 1 2 3
SAR ADC SNR variations for different FFT numbers (Read 16813 times)
niloun
Re: SAR ADC SNR variations for different FFT numbers
Reply #15 - Oct 04th, 2017, 11:59pm
sheldon wrote on Oct 4th, 2017, 12:58pm:
Niloun,
  The noise should not increase with the number of bins, just guess,
but there must be something in the way you do the calculation. Are
you adding noise voltage or noise power?
I use power as I said above:
%noise = [s(1:sigbin-1);s(sigbin+1:end)];
%snr = 10*log10( s(sigbin)^2/sum(noise.^2) )
When I use a Hann Window (which reduces signal discontinuity) there is negligible SNR variations, I guess it is something to do with that, If the calculations were wrong, ideal sine (only containing quantization noise) would also give wrong results.
RobG
Bozeman, MT
Reply #16 - Oct 8th, 2017, 4:43pm
With coherent (prime) sampling and rectangular window I see only a dB or so of SNDR variation as I increase the number of samples. Perhaps it is your "integer sampling" instead of prime sampling that is throwing it off.
I suppose the first few samples of your ADC could also be bad.
niloun
Reply #17 - Oct 8th, 2017, 9:57pm
RobG wrote on Oct 8th, 2017, 4:43pm:
Thanks RobG, I stated above that by "integer cycles" I mean integer/prime number of cycles. For example I use 7 cycles for N=64.
I have checked the digital output codes both manually and by Matlab, I don't see much difference between the first samples and the rest but maybe you are right I must try.
« Last Edit: Oct 9th, 2017, 4:44am by niloun »
RobG
Bozeman, MT
Reply #18 - Oct 9th, 2017, 9:21am
Sorry I missed that you were doing what I call prime sampling. I did not see where you told us how much it is varying - what is the change you are seeing?
You seem to be doing everything correct as far as I can tell.
DanielLam
Reply #19 - Oct 10th, 2017, 11:37am
Hi Niloun,
Can you post pictures of what your FFT's look like before and after increasing the number of bins? (say number of points > 1024). The examples where you say increasing the number of bins helps the ENOB.
I am suspecting you might be getting spectral leakage. That might be why changing bins with a Hann Window does not change much.
niloun
Reply #20 - Oct 10th, 2017, 12:14pm
RobG wrote on Oct 9th, 2017, 9:21am:
For N=64 cycles=7
without windowing: SNR=22.7184 ENOB=3.4815
with windowing:     SNR=41.6099 ENOB=6.6196
For N=4096 cycles=409
without windowing SNR=38.1335 ENOB=6.0421
with windowing:     SNR=40.0398 ENOB=6.3588
DanielLam
Reply #21 - Oct 10th, 2017, 12:21pm
Hey Niloun,
I asked for the pictures because it will tell us if you have spectral leakage or not. I can't just tell from the numbers.
Basically, I am guessing your 64 pt FFT with rectangular window (what you are calling no window) looks like the 2nd picture on this page (triangular towards the bottom of the fundamental tone).
https://www.maximintegrated.com/en/app-notes/index.mvp/id/1040
niloun
Reply #22 - Oct 10th, 2017, 12:34pm
DanielLam wrote on Oct 10th, 2017, 11:37am:
Hi Niloun,
For N=64 cycles=7 without windowing
For N=64 cycles=7 with a Hann window
For N=4096 cycles=409 without windowing
For N=4096 cycles=409 with a Hann window
niloun
Reply #23 - Oct 10th, 2017, 12:35pm
DanielLam wrote on Oct 10th, 2017, 12:21pm:
Hey Niloun,
I was preparing your answer.
DanielLam
Reply #24 - Oct 10th, 2017, 12:52pm
Just to double check, your Fin has as many digit precision as possible right? For example, for Fin = 7/64 * Fs. That is the Fin input, and you are not using 0.11 * Fs as your Fin.
Otherwise, I am a little stumped. Best advice I can give is to make an ideal ADC in matlab, and make sure that works. If that works fine, I'd suspect a rounding issue somewhere. I'm assuming these measurements were from a Cadence sim?
RobG
Bozeman, MT
Reply #25 - Oct 10th, 2017, 6:30pm
Yeah, something's messed with the 64 pt sim. You shouldn't need windowing to get the noise floor down. My best guess is that the first few samples are corrupted (either the ADC or the way you are processing the data). Sometimes this can happen if your reference is settling, but that usually produces a skirt. It is really hard to debug from here. Let us know what you find out.
niloun
Reply #26 - Oct 11th, 2017, 12:45am
DanielLam wrote on Oct 10th, 2017, 12:52pm:
Yes exactly, for instance when using N=64 and cycles=7 for Fs=200K, I choose Fin to be => 200k*7/64=21.875K
I have simulated an ideal sine (only including quantization noise) and this SNR decline didn't happen at all(with and without a window).
Yes, I have imported data from Cadence to Matlab.
Sounds that RobG is totally right, the first samples are corrupted, I will post the results below. Thanks so much for your help.
niloun
Reply #27 - Oct 11th, 2017, 1:09am
RobG wrote on Oct 10th, 2017, 6:30pm:
Thank you so much, your suggestion worked, I simulated the ADC for N=64 and cycles=7, I ran it for a longer time (640u instead of 320u) then I used output data from 320u to 640u :
N=64, cycles=7, Fin=20K, Fs=200K
One of the professors in our department said that the circuit is trying to wake up in the first conversion cycles that's why the first few samples are corrupted. I don't understand "Circuit's trying to wake up"!
I am very thankful.
RobG
Bozeman, MT
Reply #28 - Oct 11th, 2017, 7:23am
Glad that worked. Waking up just means initial transients in the reference and/or bias currents are settling out.
DanielLam
Reply #29 - Oct 11th, 2017, 9:49am
Nice one Rob. The good old transient startup times.
Pages: 1 2 3
