Apr 24th, 2024, 10:00pm
How to perform current division Cadence Virtuoso (Read 253 times)
lummiuster
Oct 19th, 2017, 8:27pm
I need to use dependent sources in my circuit. I am only aware of PCCCS and PVCCS.
What I need to do is have a current that has the following current equation:
Current =
(2.753*y^2*log(805444*x^3 + 26223*x^2 + 115*x + 1.0e-60))/(0.95930*y^2 + 1.0)/y
x is the current that flows through a DC voltage source.
y is the voltage at a node of the circuit.
How can I implement such equation?
My issue with CCCS is that we can't divide by the controlling input. i.e, we cannot do current= a/x + b/x^2...
Second issue is that I don't know any instance that lets me take as input a current and a voltage.
Third issue is to use log in my equation.
Anybody knows how I can implement such thing?
Thanks a million
Re: How to perform current division Cadence Virtuoso
Reply #1 - Oct 23rd, 2017, 7:22am
There is a "bsource" element that allows arbitrary expressions, which could probably handle this.
I'd be concerned about the expression you have, though. Eg, on the first iteration of the dc solution, many simulators start with a v-vector that is all zeros. This would probably mean that y=0 on the very first iteration, and the resulting division by zero would prevent the simulator from knowing how to change that voltage. Newton's method could also produce a negative current (x) during one iteration.
lummiuster
Reply #2 - Oct 24th, 2017, 9:35pm
Thanks a lot for your answer, this is bringing me hope. However I am having some issues with it. First I can't find it in my library. Second, I tried to follow some steps I found online on how to create a symbol but I get completely lost.
I'm a beginner. All I know is Virtuoso/Cadence, create schematic and create a symbol out of a schematic.
Can you please give me more detail on how to create the bsource symbol?
You mentioned that it might lead to some error with DC simulation. I don't think it is an issue with me as I only need transient simulation.
Thanks in advance!
Reply #3 - Oct 25th, 2017, 7:50am
But any transient simulation starts with a computation of the time-0 solution, which is a dc solution.
Reply #4 - Oct 25th, 2017, 7:54am
You shouldn't have to create the bsource symbol; it should be in a library.
Do you have an analogLib library? Where do you get the symbols for resistors, capacitors, voltage sources, etc. when you're making a schematic? Don't you see bsource in that list?
lummiuster
Reply #5 - Oct 25th, 2017, 8:16am
Yes I have analogLib. However bsource is not in it.
Do you think the first iteration could completely ruin the whole transient simulation?
Reply #6 - Oct 27th, 2017, 6:24am
It could ruin the sim - if the simulator doesn't know where to start, how can it proceed?
Could you use 1/(abs(y) + 1e-30) instead of 1/y?
lummiuster
Reply #7 - Oct 27th, 2017, 12:32pm
I don't think I can use abs(y) instead of y. because I don't know if the voltage across the resistor (y) will go negative.
Do you know how I can add bsource to my library?
Reply #8 - Oct 31st, 2017, 10:23am
If the voltage y can go negative, then it might also be zero, in which case your expression involving 1/y blows up. So, I think you need to think about what should happen in that case, and whether your equation is correct.
I don't know how to add bsource. Are you using a recent version of the software? (If you have a really old version, maybe bsource is not supported.)
Reply #9 - Dec 21st, 2017, 7:53am
The bsource component was added in analogLib in IC617 ISR6 (so relatively recently - within the last 2 years). If you're using an older version, there's this Cadence Online Support article which tells you how to create your own.
